Old 03-15-2007, 04:54 PM   #1 (permalink)
Light Racing Jounce Shok?
Does anyone have any info on this bump stop setup? Greg if you read this have you heard about a application guide on this for the titan and the price thanx for for the help every one?
nms13228 is offline   Reply With Quote
Old 03-15-2007, 05:12 PM   #2 (permalink)
Re: Light Racing Jounce Shok?
these are on a frontier, which should be the same setup as the titan. they are cool because you can adjust them externally with a small allen wrench.they are also bolt on. http://www.4x4parts.com/public_html/...7e83e43d308445
i'm not sure but some traditional air bumps ( radflo, saw, bilstein, fox, or king) might come out cheaper.
2006fronty is offline   Reply With Quote
Old 03-15-2007, 05:21 PM   #3 (permalink)
red_rider_elsinore's Avatar
Are they bolt on or welded on? Who's going to be the guinea pig?
2006 CC 4x4 Radiant Silver: Offroad Package, Tow Package
Current Mods: Glasspack muffler, Helix TB, True Flow Air Filter, Air Box Mod, Airlift Air Bags, 35x12.50x17 Big O XT LT tires, 2º Advance, 2.5" Racerunner Coilovers, Deaver MiniPack, Rear Bilstein Shocks
Wish List:Upgrade Stock Radio
2005 trx400ex: tcs Front Shocks
2001 xr650r: Tag Handlebars w/Bark Busters, Uncorked, Glass Lens Headlight, Precision Concepts Revalve, smartperformanceinc 215/VM2-K5 fork oil.
2000 yz426f: stock
1st ANNUAL GLAMIS TITAN DUNE MEET
red_rider_elsinore is offline   Reply With Quote
Old 03-15-2007, 05:39 PM   #4 (permalink)
bolt on, they fit the frontier so they SHOULD fit titans, since titan and frontier suspensions are interchangable ( titan is 3 inches wider) i'm pretty sure they will work on the front since the stock bumpstop location is the same on both arms, as for the rear ?????? i havent really looked at a titans rear suspension
Old 03-15-2007, 05:52 PM   #5 (permalink)
kartman's Avatar
LR makes good stuff.
Rebar Wrangler
Old 03-15-2007, 08:50 PM   #6 (permalink)
i would love to know if thes are a bolt on. i really want some.
crownsey54 is offline   Reply With Quote
Old 03-15-2007, 09:45 PM   #7 (permalink)
They are perfect for mid travel vehicles because they can go on the lower arm of the suspension and arent being used through so much of the travel so the truck will ride alot nicer when you are off roading.
Old 03-18-2007, 10:40 AM   #8 (permalink)
so does any one know if they are bolt on?
Old 03-19-2007, 09:52 AM   #9 (permalink)
Send a message via AIM to galaxycrew
they sure do look bolt on to me.
galaxycrew is offline   Reply With Quote
Old 03-19-2007, 07:01 PM   #10 (permalink)
DR Jon's Avatar
Hi All,
We've used the LR Jounce Shock in a couple applications. They're about 50/50 for bolt-on versus welded. I have looked at my front end with the goal of adding a jounce shock, and know that you'll have to cut off the upper bump bracket to have it meet up with the lower LR stop...which is bolted on through the same hole as the current rubber stop. You would most likely have to drill the holes required to bolt the LR bracket on.
I'm hoping to get to mine before too long, so I'll give you some feedback.
- Jon
DR Jon is offline   Reply With Quote
PRG Racing kartman Titan Pictures & Media Post 43 08-21-2007 01:07 PM
Racing Advocate07 War Stories 16 03-10-2007 01:07 PM
Window lock button. Light or no light? biggieb22 Titan Problems & Dealer Service 8 02-22-2006 02:12 PM
M1 0w-30 Racing oil JHOOTITAN Titan Engine, Transmission & Drivetrain 8 01-13-2006 12:59 AM
Racing.... who won?? socalTitan Titan Performance Modifications 18 08-02-2004 07:55 PM
