Old 03-19-2007, 08:02 PM   #1 (permalink)
loufish's Avatar
Broke my first shackle...
Broke and I haven't even hit the dirt yet...And no, I haven't been jumping it either.
I have been hitting a few good dips here around town, but man not like some guys have....We pulled it off tonite and rolled the sleeve back up and re-welded it so i can get around. Bad design, a failure waiting to happen.
This is the right side, and will be installing a set from Greg.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 03-19-2007, 09:28 PM   #2 (permalink)
PRJ
Re: Broke my first shackle...
Hey, that looks like the same thing that happened to me back in January. Passenger side went out. Waiting for the drivers side to be next.
Mine was replaced with a shackle for an F-150. Bolted right up and only cost me $50
PRJ is offline   Reply With Quote
Old 03-19-2007, 10:14 PM   #3 (permalink)
Yellomantis's Avatar
Is the entire seam welded on these? It looks like there are only 2 tack welds holding it together!!!
www.myspace.com/yellomantis
Old 03-19-2007, 11:36 PM   #4 (permalink)
loufish's Avatar
NO!....After seeing how these were built, I would have pulled them and thrown down a bead across the seam. The rubber bushing would take a little heat, but that would keep the shackle from "un-rolling"
I was supposed to go to Mexico a couple of weeks ago for the race, but this would have failed for sure down there.
Born 9/2004
2002 Honda XR650R
Old 03-20-2007, 06:14 AM   #5 (permalink)
PRJ
Nope. I only noticed 2 tack welds on each corner on mine also.
Like I said, I'm waiting for the driver side to go, otherwise I may just replace soon anyway so the spring doesn't go through the bottom of the box.
Old 03-20-2007, 08:07 AM   #6 (permalink)
Looks like I will be pulling mine and laying a good bead down when I get my lift...
Old 03-20-2007, 09:08 AM   #7 (permalink)
KUSTOMZMAN1's Avatar
that sucks for how much abuse i put mine thru...not crazy like Kartman but i had no problem blowing thru a set of whoops in the dunes or same local wash sycamore where kartman plays in...and mine held up? oh well sorry to hear that either way.
KUSTOMZMAN1 is offline   Reply With Quote
Old 03-20-2007, 10:37 AM   #8 (permalink)
Get the TC shackles, worth every penny if you are planning major roading, if not beef up the stock ones.
"Best way is to buy the 4wd knob for the cab" Kartman (refering to looking 4x4)
"Maybe you should patent your brain!" B16er
This is what your post looked like to me:
loflhsglhshgh hokkhdhok kijkhgdjd gohll ikiks ghoflpjlhdlj olpljhj plpathaih awiueao092 fhkfioph ... ,,863tryjgh thloaa VTAK 5-0794tlh;kh please help
Quote, originally posted by Capt. Blonde Beard
silver-titan is offline   Reply With Quote
Old 03-20-2007, 10:38 AM   #9 (permalink)
I heard about that, but i've never trusted ford's quality ever.
Old 03-20-2007, 10:41 AM   #10 (permalink)
I don't want to lose any lift though. I'm sure Greg will come up with something come lift time.
Old 03-20-2007, 10:56 AM   #11 (permalink)
sledge's Avatar
Same thing happened to me in October. I got a ride to the dealer, they gave me a new one and i returned the old. covered under warrenty. I didn't want to take to the dealer because of my lift.
I've been checking them every month or so for future failure.
sledge is offline   Reply With Quote
Old 03-20-2007, 11:56 AM   #12 (permalink)
PRJ
It was an aftermarket part for an F-150 that I got at a local spring shop. Not actually from Ford itself.
Besides, I'm going on visit #21 to the dealer later this week and if you look around this site, I wouldn't say Nissan's quality is very stellar either.
Old 03-20-2007, 01:58 PM   #13 (permalink)
loufish's Avatar
I believe the Ford shackle is a little wider around the spring eye...You don't want to overtighten the shackle just because it's not the correct one...
Born 9/2004
2002 Honda XR650R
Old 03-21-2007, 12:28 PM   #14 (permalink)
Valid point, enough said.
Failed rear Shackle = Leaf spring through bed!!! streetstalkerwj Titan Suspension 14 03-08-2007 11:26 AM
shackle lift? DaFridge Titan Suspension 6 11-11-2005 06:48 AM
Bed/rear shackle contact... Milehi Titan Problems & Dealer Service 6 03-01-2005 06:12 AM
Anyone ever able to find a Rear lowering/leveling shackle markislive78 Titan Suspension 0 01-05-2005 05:00 PM
Just Broke 20 Mpg Doghouse Titan General Discussion 6 03-04-2004 09:29 AM
