Old 04-17-2007, 01:21 AM   #31 (permalink)
NorCal 4x4's Avatar
Re: sway bars?
You didn't mention any aftermarket coilovers in your setup ... so if the OEM ones are still in your setup maybe they are shot ... not uncommon.
Old 05-02-2007, 11:13 PM   #32 (permalink)
LpLove's Avatar
Re: sway bars?
I highly recommend the stillen sway bar sure theres some drilling just to but its a super easy install and highly affective.
LpLove is offline   Reply With Quote
Old 05-02-2007, 11:14 PM   #33 (permalink)
LpLove's Avatar
Re: sway bars?
sorry failed to mention I was talking about the rear but the front is also very good
Old 05-08-2007, 04:00 PM   #34 (permalink)
Justintoxicated's Avatar
Re: sway bars?
Originally Posted by hooligan
i like Kartman removed mine. best thing i've ever done to my truck. i also have the same coilovers as kartman so the higher spring rate makes up for not having the swaybar somewhat so an increase in body lean is a little bit more noticeable, however if one were to take off the sway bar in front without having coilovers with a higher spring rate, you'll perhaps think you're going to roll over...
all depends really on what purpose your truck is going to serve you. i absolutely love the way it handles now that it is off!
Was your truck at Superior Nissan Last Saterday?
Old 05-08-2007, 04:13 PM   #35 (permalink)
sledge's Avatar
Re: sway bars?
has anyone installed the sway bars, front and rear, on a lifted Titan? how much did it improve the handling?
sledge is offline   Reply With Quote
Old 05-09-2007, 07:59 PM   #36 (permalink)
LpLove's Avatar
Re: sway bars?
I've got the 4" spindle lift and the leveling with a 4" block. I added the front right after the lift and didnt really notice much but it helped alittle then added then I added rear sway bar and there was a tremendous difference ( both were Stillen) .Even tho the stillen rear sway requires drilling it only calls for two holes It's a simple and affective ins tall.
Aftermarket Sway bars for Titan? royr Titan General Discussion 7 12-26-2006 06:53 AM
shocks and struts, sway bars supertitan Titan Suspension 4 04-15-2006 11:00 AM
sway bars jd1973 Titan Suspension 1 09-23-2005 04:25 PM
Sway Bars or Eurathane bushings? CobraGMike Titan Parts & Accessories 3 04-07-2005 03:53 PM
Anyone know of a source for rear sway bars? Crankrod Titan Performance Modifications 7 02-15-2005 08:23 PM
