I just got an 07 XE. Some friends of mine said I should put some sway bars on it. I was just wondering if they are even worth my time? Do they make much of a difference?
I put a hellwig sway bar on the rear on my 05 le and the difference was huge in handling, cornering was great no more body roll.
its worth it.
07 smoke le cc
graphite leather
OR BT dvd/nav
side airbags
sunroof step rails
bed divider
bed extender
sliding overhead racks
sirius sat
underseat storage
i like Kartman removed mine. best thing i've ever done to my truck. i also have the same coilovers as kartman so the higher spring rate makes up for not having the swaybar somewhat so an increase in body lean is a little bit more noticeable, however if one were to take off the sway bar in front without having coilovers with a higher spring rate, you'll perhaps think you're going to roll over...
all depends really on what purpose your truck is going to serve you. i absolutely love the way it handles now that it is off!
Except my truck corners better on the street without a swaybar.
No more front end push, huh?
PRG Performance Kit w/SAW's
Born 9/2004
so i have sway bars stock on mine ? i have an 07 se cc 4x4 bt or (long list lol) but yeah how much are they and ill be driving on thew street 99% of the time so should i get them ?
IMO a much better upgrade than rear sways or aftermarket front sway bars is the DR or Bilstein rear shocks from PRG. My first mod was the PRG modified Bilstein rear shocks, and they made my Titan feel like it was on rails when cornering.
Btw, because of the softer springs on the stock front coil-overs, probably not a good idea to disconnect them ... or if you do experiment, at least mention it to your wife if she drives it too. Lol
price on any of that ? so your saying leave the front alone and just put better shocks in the back ? i dont knoe if this has anything to do with it but my neighbor has a lifted ranger and hes got 3 shocks on each side. opinions ?
