Old 04-09-2007, 08:10 PM   #1 (permalink)
Gonpostal's Avatar
Installing Deaver Question?
Is it better to leave the stock leaf on or take the whole thing off to install?
Mods: CST spindles, DR coilovers, PRG UCA, Bilstein rear shocks, 1.5 deavers, OR Traction Bars, 3 inch BL, N fab bars, AEM Brute force intake, Banks exhaust, Bully Dog, 18x10 Mazzi Hulks, 37x12.50 M/T Toyo O/C.(Next Mod....Gears from hoopers and Diff Cover.
Gonpostal is offline   Reply With Quote
Old 04-09-2007, 08:40 PM   #2 (permalink)
loufish's Avatar
Re: Installing Deaver Question?
I did my install with the leaves in place, but if I was to do it again with air tools, I might just pull off the spring and do the mini-pak install on the bench.
Getting the overload off is easy, it takes a little more hassle to get the pak on afterwards...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 04-09-2007, 08:45 PM   #3 (permalink)
I did it with springs on. A long drift or punch to align the leaves (don't use the bolt to align or you may strip the threads) and some forged C-clamps. If you are keeping the stock shackles, I would keep an eye on them as they seem kind of weak.
Help Installing the Deaver 2-1/2" pack Mikehos Titan Suspension 6 12-05-2006 08:30 PM
Question Help Installing Speakers... johnnyeagle Titan Visual & Audio Discussion 1 08-09-2006 11:48 AM
Question about installing speakers... johnnyeagle Titan Interior Discussion 0 08-09-2006 09:16 AM
Question after installing my 22's Titano24's Titan Wheels, Tires & Brakes 6 01-19-2006 09:47 PM
Question installing Truxedo cover PortlandTitan Titan General Discussion 1 06-14-2005 04:06 PM
