Old 04-15-2007, 06:48 PM   #1 (permalink)
XterraChad's Avatar
Send a message via ICQ to XterraChad Send a message via AIM to XterraChad Send a message via MSN to XterraChad Send a message via Yahoo to XterraChad
To Those with Hellwig Traction Springs
I'm installing my heavy duty hellwig traction springs today... And I just want to make sure this is right....
Does anyone have pics of the red helper spring towards the front of the truck? All the pics I've seen just show the spring torwards the axle, and not how it looks towards the front of the leaf.
It seems that the front piece of the spring is getting real close to the clamp towards the front of the factory leafs, is the ubolt supposed to go in front of this clamp, towards the front of the truck, or behind the clamp towards the rear of the truck... I can't really get the rear piece of the spring any closer to the axle, as its almost touching the factory ubolt mounts. attached are some pics:
Thanks for the help...
Chad
2007 Titan CC SE 2WD
PRG Mini-Lift - 22x9.5 Chrome SWG-781's-305/45/22- Hellwig Traction Springs
Audio: JVC-AVX800 HU, CDT ES620 Comps (Front) CL61 Comps (Rear), Rockford P5002 (Component Amp) Single Memphis 10 - Tech12Volt Box - Rockford P3001 - Sub Amp
XterraChad is offline   Reply With Quote
Old 04-15-2007, 08:06 PM   #2 (permalink)
sudden urge's Avatar
Re: To Those with Hellwig Traction Springs
You made good decision going with the Hellwigs. Retighten them after a few days, and make sure you have rear mounting clamp as close as possible to the axle. Here are some of my pics:
Edit: I just noticed you have a 1" spacer block. I'm not sure if that moved your mounting point forward by a 1/2". Look at my pic of the front, and you will see that my front clamp is just before the factory spring clamp thingy, the curved end of the Hellwig actually pushes up against it, not on top of it, when tightened down. I do have the HD Hellwigs and wonder if mine are a 1/2" shorter than your set. Also, you should use the extra locking nuts they gave you.
those-hellwig-traction-springs-p7030002.jpg  those-hellwig-traction-springs-p7030003.jpg  those-hellwig-traction-springs-p7020009.jpg
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Latest 1/4 mile time of 14.632 running BD reg 87 tune +2 timing. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
sudden urge is online now   Reply With Quote
Old 04-15-2007, 09:03 PM   #3 (permalink)
I just went in the garage tonight and took two pics of the front clamp mount to give you a better idea.
those-hellwig-traction-springs-p4150001.jpg  those-hellwig-traction-springs-p4150002.jpg
Old 04-15-2007, 09:29 PM   #4 (permalink)
XterraChad's Avatar
I didn't really think about that 1" block... maybe that kinda changed things a bit. I have the HD ones too, so they should be the same... Hmm...
Thanks for taking the pics....
Old 04-15-2007, 09:44 PM   #5 (permalink)
TitanHigh's Avatar
what is the part number of the helper springs you bought. reason i ask is every time i have called hellwig they tell emthey do not offer a heavy duty set up for the titan.
2005 Titan Smoke Crew Cab LE
9.5 inches of suspension lift
FOX Coil-Overs Up Front
FOX 2.5 shocks and Air-Bags In the Rear
3 inch Boddy Lift
Riding on 18's with 37's soon
TitanHigh is offline   Reply With Quote
Old 04-15-2007, 09:53 PM   #6 (permalink)
They are traction springs, not helper springs. Their only purpose is to eliminate axle wrap. They are sold exclusively at JC Whitney and made by Hellwig.
Old 04-16-2007, 10:07 AM   #7 (permalink)
I am having the exact same problem...I also have 1" blocks. I was thinking about grinding about a 1/4" off the front and rear of the traction springs.
TitanJim is offline   Reply With Quote
Old 04-16-2007, 07:56 PM   #8 (permalink)
XterraChad's Avatar
Good idea... I'm going to play around with them again this weekend... I guess you can just get some red spray paint to paint the exposed ends once you grind them....
More than likely, its probably because they aren't exactly installed right, while they did reduce axle wrap, I still have a little from a dead stop.... I'm pretty confident that when I get them in there right, it will eliminate it completely.
Old 04-16-2007, 08:24 PM   #9 (permalink)
Once you get them in right, you won't have any axle wrap. You have to get them in so they are touching the upper spring on both ends, then it will act like another leaf was installed.
Old 04-16-2007, 09:39 PM   #10 (permalink)
I think the HD ones are a bit longer. I believe it is about 2 inches longer. I have the standard ones and I am about 2 inches from the clamp.
PRG 2" front lift. 1" rear drop shackles
Wet Okole Front seat covers
Herbpov is offline   Reply With Quote
Hellwig LP 15 helper springs Winter Texan Titan General Discussion 2 10-19-2006 07:39 AM
Follow up reportafter having Hellwig HD traction springs after the first week. sudden urge Titan Suspension 6 07-03-2006 10:45 AM
Hellwig helper springs? Lairdo Titan Suspension 7 05-07-2006 07:21 PM
CO: Hellwig sway bar teamgl Buy/Sell 10 02-15-2006 08:40 PM
Hellwig Helper Springs Rotorheader Titan Parts & Accessories 0 04-05-2005 07:33 PM
