Old 06-09-2007, 08:29 PM   #16 (permalink)
Re: SuspensionMax Leafs
Originally Posted by jkelley3209
spring helpers that you can buy from autozone or pepboys for about $22 dollars ... they help prevent wheelhop and give u better traction...its deff worth it ... they take about 10 mins... to DIY
Does the spring helper mod make the ride stiffer though? My truck rides so rough already I am thinking about removing a leaf spring, has anyone done that yet by the way?
05 Titan KC SE - Smoke, BT
Nismo CAI, FlowMaster 40 SI/SO 3", Timing Advance, TB Bypass, 5% tint, Smoked Tails, Armada Lip, De-badged, Silverstar Ultra's.
Best ET 15.32@90.8 2/8/08
Wife's Car: 02 Altima 3.5 SE 5MT - Mystic Emerald Nismo CAI, VIAS Plate Removed, Royal Purple Fluids, Jim Wolf Clutch/Flywheel, Dual Magnaflow w/ OEM Resonator Removed, Nitto NT555 245/45/17, De-badged
Best ET 14.16@100.4 2/8/08
Titan5683 is offline   Reply With Quote
Old 06-09-2007, 08:54 PM   #17 (permalink)
Yes, the helpers stiffen the ride a bit, as does just using a clamp on the springs. It is a tradeoff, it lowers the truck a bit by compressing the springs, which makes them stiffer and thus resists axle wrap. But it makes the ride a little stiffer.
Many people (including me) have replaced the overload leaf with a Deaver spring pack from PRG.
www.prgproducts.com also sells lowering springs that maintain load and towing capacity, as well as heavy duty shackles.
anyone do add a leafs and the new leveling kit? Hawaiianbasshead Titan Performance Modifications 0 10-24-2004 01:12 PM
