Old 06-28-2007, 07:53 PM   #1 (permalink)
erric's Avatar
3 inch level kit
i know that 33's clear on the stock rims, but i just got new 18inch rims and theres no way my old 33's will clear on the new rims because of the off set. so does anyone know if a 3 inch level kit will clear some 33 inch toyo mt's with an off set rim? please let me know
erric is offline   Reply With Quote
Old 06-28-2007, 08:33 PM   #2 (permalink)
jguns2002's Avatar
Re: 3 inch level kit
What are the specs on the wheels?
jguns2002 is offline   Reply With Quote
Old 06-28-2007, 08:38 PM   #3 (permalink)
SDTitan1's Avatar
i've never seen a 3" leveling kit.........any details on the kit you were considering?
SDTitan1 is offline   Reply With Quote
Old 06-28-2007, 09:01 PM   #4 (permalink)
Yellomantis's Avatar
The stillen kit ends up being a 3 - 3.5 inch lift in the front. I learned that the hard way!
2006 4X4 LE OR CST 7" Lift, RadFlo 2.5 coilovers, PRG Uppers, RadFlo 2.0 rears, Deaver 2.5 mini pack, 3" custom block, PRG traction bars, TC HD rear shackles, 2* advance, Custom Supertrapp exhaust, XE mirror covers and door handles, 17X8 AR Mojave Teflon's, 35/12.50R17 Toyo Mud Terrains, Bushwacker fender flares.
www.myspace.com/yellomantis
Old 06-28-2007, 09:09 PM   #5 (permalink)
BIGDADDY"S-07-CREW's Avatar
Hey yellow, more info on the stillen please. Was there alot of coil bucket rubbing, or any other problems with it?
BIGDADDY"S-07-CREW is offline   Reply With Quote
Old 06-28-2007, 09:22 PM   #6 (permalink)
The UCA basically was slamming into the coil bucket every time I hit a bump in the road (on rebound). I told stillen about the problem, but their answer to my issue was "the spacer is 2 inches thick, it's only going to lift the front 2", it's a 2" leveling kit." Shows what they know. A 2" lift/leveling spacer in our trucks should only be about 1.3" thick. Greg knows the actual measurement.
Old 06-28-2007, 10:17 PM   #7 (permalink)
loufish's Avatar
i hate to be the "bad" guy, but why did you buy those wheels if they aren't going to work?
What is the backspacing?
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 06-30-2007, 01:05 PM   #8 (permalink)
erric's Avatar
i had got a killer deal on the rims and just thought my toyo mt's would look good on them and i didnt realize the offset was different. i just hope the 3 inch kit makes them not rub. check out the 3 inch @ roughcountry.com
Can you guys post some 2.5 inch PRG level kit pictures of your Titans? ibbodyboarder Titan Suspension 28 06-30-2007 08:29 PM
4 inch vs 6 inch lift Groupleader Titan General Discussion 1 06-06-2007 09:01 AM
2 inch ncd level kit StuntDriver06 Titan Suspension 35 03-23-2007 05:19 PM
WTT 18 inch for 17 inch wheels blueskys Buy/Sell 0 11-06-2006 03:07 PM
Before I get my level kit from PRG.......... ibbodyboarder Titan Suspension 9 09-21-2006 06:44 PM
