Old 01-05-2009, 12:07 PM   #31 (permalink)
rtc1184's Avatar
Send a message via AIM to rtc1184 Send a message via Yahoo to rtc1184
Re: Titan Lift and Shock Overview
Originally Posted by CLAREMONTTITAN View Post
I have the 6" fabtech lift currently on my CC with 35" grapplers & 18". What can I buy to add some extra inches other than a body lift? Please let me kno the name of the product and the best brand that makes it! Thanks! 2WD btw
you can get saws for the front and buy the ones for a 4wd, deaver c-30 pack, 4" rear block, prg uca's, prg or total chaose shackles
2007 KC 2wd White
modswanted: UPREV ECU FLASH
BIG BRAKE UPGRADE
STEEL BRAIDED BRAKE LINES
MASTER CYLINDER STIFFNER
REMOTE START
REPLACEMENT BUMPERS
BULLETPROOF FRONT CLIP
SHACKLE FLIP THE REAR
MODS DONE!
REMOVED ALL THE DECALS,TINT, CAI, STRAIGHT PIPE EXHAUST, BALLISTIC OFFROAD JESTER'S 17X 9 -12MM OFFSET, 6" BASIC FABTECH LIFT, STACKED LEVELING KIT, 37x13x17 SUPER SWAMPER BOGGERS, 3"BODY LIFT, HITCH, 1 - 15" KICKER SOLO BARIC L7, CRUNCH 1500.1 AMP, THROTTLE BODY SPACER, PAINTED INDIGO BLUE INTAKE COVER,BURNOUT MOD,LED 3RD BRAKE LIGHT, BLUE LED'S UNDER DASH, WHITE FACE GAUGES, TB COOLANT BYPASS, AXLE VENT MOD, 2* TIMING ADVANCE, SUPERCHIPS PROGRAMMER, BLUE L.E.D. DOME LIGHT, CUSTOM MADE ROCK SLIDERS, DDM 35W 8000K LOW BEAM, DDM 35W 8K HIGH BEAM, MILE MARKER 12,000LB WINCH, 8-6" 100WATT OFFROAD LIGHTS, MY MADE LIGHT BAR, MY MADE FRONT BUMPER WITH WINCH MOUNT, LINE X BEDLINER, LINE X ROCK SLIDERS, LINE X ROCKER PANELS AND BOTTOM OF THE BED,
10.5" INGSIGNIA MOTORIZED FLIP DOWN SCREEN, SONY XPLOD W/ BUILT IN BLUE TOOTH AND AUX PORT, BACK UP CAMERA
www.myspace.com/stuntin4alivin
rtc1184 is offline   Reply With Quote
The Following User Says Thank You to rtc1184 For This Useful Post:
CLAREMONTTITAN (04-08-2009)
Old 04-03-2009, 05:20 PM   #32 (permalink)
shanky333's Avatar
Anyone try out the new Rancho quick lift shock? There is also another brand ? that is an adjustable coil over shock thta you can get 3"'s of lift out of???
Shanky
shanky333 is offline   Reply With Quote
Old 04-03-2009, 05:59 PM   #33 (permalink)
The Rancho quick lift shock is garbage. It only gives about one inch of lift and the set I received were defective so they didn't rebound properly so they basically rode like old shocks. I actually got the quicklift shocks replaced with a daystar leveling kit and the second cheapest procomp struts that they make for the titan and the ride is way better plus it actually looks like i lifted the front of the shock.
I posted a minireview in the suspension section that I have been meaning to update with pictures.
The rsx900xL are ok. I have those in
AOTitan is offline   Reply With Quote
Old 09-09-2009, 12:44 PM   #34 (permalink)
silverstar's Avatar
Thank you Greg for this post. I am looking over lifts right now because i'm hoping to buy one in about a year. This helped me lean even further towards the PC with SAW's up front. I hope I have enough to get the SAW's right off the bat, but if not it'll give me something to look forward to uprgrading to. That and the deaver pack in the rear. Thanks again.
08 Titan SE 4x4 KC. Magnaflow X-pipe muffler with dual 2.25" tailpipes, Hypertech Max energy. 14.85@91.8 best time(9.49@74 in the 1/8th). 6000k H.I.D. low beams. 302.8rwhp before the hypertech.
silverstar is offline   Reply With Quote
Old 09-24-2009, 04:38 PM   #35 (permalink)
is this good? Performance Accessories Premium Lift Systems offer an affordable solution for truck and SUV owners. Combining Performance Accessories' body lift, leveling kit, and gap guards, Premium Lift Systems are the most economical way to raise your vehicle between 5 - 6 inches. Premium Lift Systems deliver the most lift for the money of any lift solution available today! Premium quality and appearance, without the premium price tag!
Kit Contains:
3" Performance Accessories Body Lift Kit
2.5" Spacer Leveling Kit
Gap Guards
All Necessary Hardware & Detailed Instructions
Additional Information:
Maximum Tire Size: 33"
Stock Shocks Are Retained!
Body Lift Features:
AFFORDABILITY: Performance Accessories body lift kits are a very affordable option when considering lifting a vehicle; in some cases a Performance Accessories body lift can be as much as 3 times less than a comparable suspension system.
RIDE: Since body lift systems do not alter or change suspension components there is no deterioration of the quality factory ride.
WARRANTY: Since Performance Accessories body lift systems do not change or alter factory parts, the factory warranty is not affected.
GREATER APPLICATIONS: Due to our professional engineering staff, Performance Accessories is usually the first to offer a lift for new vehicles or difficult to fit vehicles. Performance Accessories also offers body lift kits for many diesel applications.
LARGER TIRES: The primary reason for a consumer to lift their vehicle is that they want to install larger tires and wheels. A body lift from Performance Accessories allows the consumer to increase two to three tire sizes.
2WD vs. 4WD: Most Performance Accessories body lift systems fit both 2WD and 4WD vehicles. With 2WD kits available back in the 1980's Performance Accessories was the first to market with a lift for 2WD vehicles.
VALUE: When you combine the many reasons listed above, Body Lift systems from Performance Accessories are by far the best value when lifting a vehicle.
Tech Notes:
Will not fit vehicle equipped with diesel engine.
Steering extension included.
Rear bumper brackets are to enhance appearance only, bumper cannot be used for towing.
Requires cutting the lower radiator core support and installing new brackets provided.
Front end alignment highly recommended.
tell me what you think
5.5" 04-09 Nissan Titan Premium Lift System/Kit - Top Gun Customz
paradysz is offline   Reply With Quote
Stock Titan Shock Upgrade PRJ Titan Suspension 11 02-18-2007 09:10 AM
Stock ride height Titan 4x4 off road : Looking for better front shock doctor steve Titan Suspension 2 03-06-2006 10:58 AM
War on Terrorism, Strategic Overview ruauman2 Off-Topic Discussion 93 07-29-2005 02:03 PM
squeaky shock?? KnoxTITAN Titan General Discussion 4 07-05-2005 12:56 PM
Daystar lift and shock issues... workman1000 Titan Interior Discussion 2 05-09-2004 12:18 PM
