User Name
Password
Installed coilovers, but how do I raise them now? - being discussed at Nissan Titan Forums in the Titan Suspension section.
Old 12-04-2007, 08:14 AM   #16
payyourtoll
payyourtoll's Avatar
Re: Installed coilovers, but how do I raise them now?
Right, they have two color nuts that tighten to each other and lock the coil in place. I am obviously lowering the bottom one away from the upper, and trying my best to raise the upper, just inches with a rubber mallet. WD40 and PBBlaster did nada. I swear I am not as dumb as I sound.
'06 CC LE
payyourtoll is offline   Reply With Quote
Old 12-04-2007, 08:21 AM   #17
wakeboarder2186
just make sure the suspension is completely unloaded, nothing can be putting any stress on the coilovers. mine only spun after wd40
Its got a lift and some tires....meh its fun
wakeboarder2186 is offline   Reply With Quote
Old 12-04-2007, 06:02 PM   #18
AppleJacks
be sure that you arent using the lower control arm to jack up the truck.
dont know what else would make it so hard? more elbow grease? jk
AppleJacks is offline   Reply With Quote
Old 12-05-2007, 06:31 AM   #19
payyourtoll
I also have CST spindles, they must be putting pressure on the c/o and making things tough
Old 12-05-2007, 09:46 AM   #20
kartman
kartman's Avatar
Spindles should not matter. Post a pic of your shocks, something sounds very wrong.
Rebar Wrangler
Old 12-05-2007, 06:59 PM   #21
GR8WHITE
GR8WHITE's Avatar
My dr. coilovers were a PITA to adjust they have a set screw, i blew them off with air first then i shot alot tri flow (like wd40) on them and they only have a single collar and used a bar on the end on the spanner wrench and is was hard as hell to get them to adjust up. i had tein super drifts on my silvia that were relatively easy with one hand to adjust but the tension on these big thick springs for our heavy trucks (compared to little import cars) is alot, so when you are cranking them for more lift you are trying to compress those huge coils. hope this helps you out.
GR8WHITE is offline   Reply With Quote
Old 12-06-2007, 09:55 AM   #22
payyourtoll
Old 12-06-2007, 12:04 PM   #23
kartman
kartman's Avatar
Hmm ,never seen the RFs mounted can down before, only the SAWs.
Old 12-06-2007, 02:11 PM   #24
galaxycrew
Send a message via AIM to galaxycrew
i thought that was strange too...
galaxycrew is offline   Reply With Quote
Old 12-06-2007, 02:39 PM   #25
Bomber52
The 2.0 shocks are mounted can down. The 2.5 shocks are mounted can up.
Glenn
Radflo Suspension Technology
714 965-7828
www.radflo.com
Bomber52 is offline   Reply With Quote
Old 12-06-2007, 03:03 PM   #26
kartman
kartman's Avatar
Glenn
That explains it, I was thinking they were 2.5s.
User Name
Password
Want to raise DWBTITAN421 Florida Forum 5 06-28-2007 05:44 PM
Raise center console height Titan_LE Titan Interior Discussion 2 05-26-2007 03:00 PM
wanting to raise my front end 2" Canine Titan General Discussion 2 02-05-2007 03:28 AM
Fox coilovers are now installed... ptgarcia Titan Suspension 30 10-04-2005 02:42 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
