User Name
Password
Click Here
Installed coilovers, but how do I raise them now? - being discussed at Nissan Titan Forums in the Titan Suspension section.
Old 12-02-2007, 08:59 AM   #1
payyourtoll
payyourtoll's Avatar
I installed some Radflo 2.0 coilovers, now I want to raise them a bit higher.
Do they need to come off the truck to raise or can they stay on and be raised somehow?
'06 CC LE
payyourtoll is offline   Reply With Quote
Old 12-02-2007, 09:31 AM   #2
loufish
loufish's Avatar
Re: Installed coilovers, but how do I raise them now?
You should be able to increase the spring pre-load by raising the truck to unload the suspension and the use the spanner to to tighten up the spring collar on the shock body. Be sure to loosen up any set screws on the collar first.
PRG Performance Kit w/SAW's
Nitto Terra Gobblers on factory OR wheels
Born 9/2004
2002 Honda XR650R
Old 12-02-2007, 10:09 AM   #3
payyourtoll
thanks Lou, I had the truck in the air and weight off the coilover (less the a-arm and spinlde force). I can only budge the spring collar up with rubber mallet on the spanner. Impossible by hand. Never had c/o on a truck before, but on all of my sports cars it was an easy twist to raise or lower, just thinking these are different?
Old 12-02-2007, 10:22 AM   #4
yamatitan
yamatitan's Avatar
I have never done these before on a truck. But i know on my Grizzly atv their is no way in hell i am going to turn my schocks with a regular spanner wrench. I have to jack it up and put some type of cheater bar on the end of the wrench to get leverage. Make sure they is not some time of stops that you have to unscrew before you can turn it.
Old 12-02-2007, 12:07 PM   #5
TitanmediC
ya like lou said make sure u unscrew that allen set screw or you'll eff up the threads and have one helluva time turning it
TitanmediC is offline   Reply With Quote
Old 12-02-2007, 06:43 PM   #6
loufish
loufish's Avatar
Actually I have a 2' pc of tubing I slide over the spanner, and turn the wheels to one side...I also spray WD-40 on the ring and threads to help things turn.
Old 12-02-2007, 10:09 PM   #7
wakeboarder2186
wd40 between the springs and the pearches helped me. otherwise it doesnt like to spin
Its got a lift and some tires....meh its fun
wakeboarder2186 is offline   Reply With Quote
Old 12-03-2007, 10:14 AM   #8
galaxycrew
Send a message via AIM to galaxycrew
where is the set screw located? and i have the remote reservoirs. so is it okay to loosen the elbow coming off of the shock to get the spanner through? sorry, i made another thread, but no one is responding...and so far, this thread has been pretty helpful...thanks
galaxycrew is offline   Reply With Quote
Old 12-03-2007, 04:05 PM   #9
payyourtoll
bump for above Q and looking for a clear yes/no on raising the truck without removing c/o?
Mine dont move
Old 12-03-2007, 04:43 PM   #10
TitanmediC
NO u don't need to remove the coilover to raise it just jack up the front end to release the compression so its easier to crank. i hope thats clear enough cuz i'm out of ideas...
and to explain the set screw in easy words its located on the part that you put the spanner wrench on and turn hence the reason why u need to loosen it to turn it. have u looked at ur coilovers yet at all?
Old 12-03-2007, 04:46 PM   #11
galaxycrew
but where is this "allen set screw" that i hear of? its driving me nuts! and can i loosen the elbow of the remote reservoir hose to move it out of the way?
Old 12-03-2007, 05:38 PM   #12
Bomber52
There is no set screw on the Radflo Shocks, the 2 nuts lock together.
Glenn
Radflo Suspension Technology
714 965-7828
www.radflo.com
Bomber52 is offline   Reply With Quote
Old 12-03-2007, 06:00 PM   #13
kartman
Banned
kartman's Avatar
Are you trying to spin both collars together? That would make it a lot harder.
Old 12-03-2007, 06:04 PM   #14
galaxycrew
glenn answered my questions for me...what i really needed to hear was that there is NO set screw..i got confused from an earlier post. but i guess that was in regards to the 2.0. sorry for hijacking payyourtoll
Old 12-03-2007, 07:25 PM   #15
loufish
loufish's Avatar
Re: Installed coil overs, but how do I raise them now?
It sounds like the Radflo's have 2 body nuts tightened against each other to provide the locking, if so they need to be unlocked before trying to adjust the preload
User Name
Password
Want to raise DWBTITAN421 Florida Forum 5 06-28-2007 05:44 PM
Raise center console height Titan_LE Titan Interior Discussion 2 05-26-2007 03:00 PM
wanting to raise my front end 2" Canine Titan General Discussion 2 02-05-2007 03:28 AM
Fox coilovers are now installed... ptgarcia Titan Suspension 30 10-04-2005 02:42 PM
Search this Thread:
Advanced Search
vB code is On
