Old 12-12-2007, 08:39 PM   #1 (permalink)
SSgtLE08's Avatar
2.5 leveling kit. void warranty?
i bought a 2.5 NCD leveling kit and i want to know if the kit voids any part of the factory warranty? also, do i need to bumpstops?
SSgtLE08 is offline   Reply With Quote
Old 12-12-2007, 09:14 PM   #2 (permalink)
helomech's Avatar
Re: 2.5 leveling kit. void warranty?
No it will not void your warranty, and bumpstops are a great idea. That is why I bought the prg kit, it came with them.
Old 12-13-2007, 06:31 PM   #3 (permalink)
I bought the same kit for my 4x4 but it came with bumpstops. If I install the kit with the bumpstops will I have any problems? I'm not planning on taking it off road.
nsunz11982 is offline   Reply With Quote
Old 12-13-2007, 06:36 PM   #4 (permalink)
helomech's Avatar
Install the bump stops, there is no reason not to.
Old 01-12-2008, 07:11 PM   #5 (permalink)
husker1206's Avatar
35x12.50's
Has anyone ever put 35x12.50's Nitto Mud Grapplers on the stock 18" wheel with just a leveling kit?? Pic and comments would be helpfull. Thanks
husker1206 is offline   Reply With Quote
Old 01-12-2008, 09:10 PM   #6 (permalink)
EVO8's Avatar
The only thing with the bump stops is, you have to drill the hole larger. The aftermarket bump stop thread that Greg sells is just slightly bigger.
2006 Titan XE 4x4 (PRG 4" Performance package)
2003 Evolution VIII (358awhp/354awtq) that's on 91octane,stock boost, stock turbo.
2007 GSXR1000 (not enough road to touch redline)
"Dream as if you'll live forever, live as if you'll die tommorow" : James Dean.
EVO8 is offline   Reply With Quote
Old 01-13-2008, 07:01 PM   #7 (permalink)
I have a 2.5" level kit on my from Top Gunz. We put the truck on a lift and used another jack to cycle the suspension as far up as possilble and let it hange all the way down and I could not make anything hit. I am only running stock 275/70/18's so if you are going bigger then it may be an issue.
I have a 2008 KC Pro-4x and I was told that the bump stops were for the 2wd trucks with softer springs.... I have no idea if that is true.
Winder is offline   Reply With Quote
Does TBS void warranty? Ourbaby Titan Performance Modifications 32 07-01-2007 11:01 PM
void warranty ldizzle_sks Titan Performance Modifications 8 04-05-2007 04:15 PM
Lift void my warranty? remembermytitan Titan General Discussion 8 11-09-2006 08:37 PM
Void Warranty?? HSUReddiePB Titan Performance Modifications 10 09-07-2006 09:53 AM
