LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 08-02-2009, 07:00 PM   #1516 (permalink)
loufish's Avatar
Re: "Prerunner" Titan's
They do awesome work. You have to get some action shots when its all said and done.
When we get all the parts togather and start there will be plenty of build-up photos...My son and I will be doing the fabrication and install of the hoop, engine brace and front tube bumper...oh yeah and the glass fenders....
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 08-03-2009, 09:38 PM   #1517 (permalink)
kartman's Avatar
Originally Posted by Just-in View Post
is 4130 1.75x.120 tubing suitable for a bumper or does it need to be DOM tubing?
Thats overkill, so is DOM if you are not racing. Save money and use mild.
Rebar Wrangler
Old 08-03-2009, 09:53 PM   #1518 (permalink)
Darkside's Avatar
^^ Agree with Kartman. That's all I was going to get for my bumper was mild steel. Now I just need to find a welder/fabricator to do it for me. lol
Mods:PRG Mid Travel Kit * SAW Coilovers custom valved by PRG * Glassworks Unlimited Fenders * C-30 Deaver Pack * Rear: Fox Shocks * PRG HD Shackles * Mag-Hytec Diff. Cover * Powerslot (Slotted) Rotors * Xenon HID Low Beams * 35" Kumho Road Venture M/T's * Custom Front Prerunner Bumper by Pirate Labs * 7" HID O/R Lights
Darkside is offline   Reply With Quote
Old 08-03-2009, 10:16 PM   #1519 (permalink)
If you need a good front bumper made try desolate motorsports in whittier. Greg does great work at even better prices.
04 CC Long travel
sblbdr is offline   Reply With Quote
Old 08-03-2009, 10:20 PM   #1520 (permalink)
CL 8 2WD's Avatar
Use PRGreg's fabricator Roy, he's over by you.
And he's very good
http://liftedimports.com/index.html
http://www.youtube.com/user/LiftedImports
06 SMOKE SE KC 2WD TITAN /AEM INTAKE/FLOWMASTER 40/CST 4" LIFT SPINDLES/2.5 X 8" TRAVEL RADFLO COILOVERS W/ REMOTE RESERVOIR / PRG DELIUXE MID-TRAVEL KIT /DEAVER 2.5 MINI PACK/2.5 X 10" TRAVEL RADFLO REAR SHOCKS /PRG OFF ROAD TRACTION BARS/ CST CARRIER DROP/PRG HD SHACKELS/ULTRA ROUGE 17X8 WHEELS/37X12.50R17 HANKOOK DYNAPRO MT/HOOPERS CUSTOM 4.56 GEAR INSTALL W/TRUETRAC AND MAG-HYTECH DIFF.COVER/ALLIED MOTORSPORTS PRG MID TRAVEL SET UP CUSTOM FAB FRONT & REAR BUMPERS/BULLY DOG HIGH OCTANE TUNE +2* DISABLE WIDE OPEN THROTTLE GOVERNOR
CL 8 2WD is offline   Reply With Quote
Old 08-03-2009, 10:26 PM   #1521 (permalink)
CL 8 2WD's Avatar
He's a nice guy, does he still have the shop ?
Old 08-03-2009, 11:19 PM   #1522 (permalink)
BAD 24/7's Avatar
I want to put some prerunners on my titan, but I want to make them out of steel, not like the fiberglass fabrications out there. Has anybody on here tried that?
BAD 24/7 is offline   Reply With Quote
Old 08-04-2009, 08:23 AM   #1523 (permalink)
pipho's Avatar
What are you talking about? You want to put some pre runners, what is that? Are you talking pre runner fenders because thats not what makes a pre runner its the suspension, the ability to pre run a race. Why would you go though all the trouble to make bulged metal fenders when it is way quicker and cheaper just to buy some fiberglass?
pipho is offline   Reply With Quote
The Following User Says Thank You to pipho For This Useful Post:
Just-in (08-04-2009)
Old 08-04-2009, 12:11 PM   #1524 (permalink)
kartman's Avatar
And he's very good
IF you have 2 years to wait for a bumper.
Rebar Wrangler
Old 08-04-2009, 12:21 PM   #1525 (permalink)
Just-in's Avatar
yeah not looking to race... want some strength though it is my Daily driver and all.
should I shoot for the .120 wall still?
Just-in is online now   Reply With Quote
Old 08-04-2009, 12:22 PM   #1526 (permalink)
Just-in's Avatar
your not gonna be able to fabricate one off's for less than you can buy the glass most likely...
Old 08-04-2009, 10:03 PM   #1527 (permalink)
kartman's Avatar
1.75 .120 wall mild steel.
Rebar Wrangler
The Following 2 Users Say Thank You to kartman For This Useful Post:
Just-in (08-08-2009), ryands650x (08-07-2009)
Old 08-08-2009, 07:57 AM   #1528 (permalink)
loufish's Avatar
Repaired my bent frame yesterday, it took about 6 hours on the frame rack...The hitch and rear bumper were bent from the T/C so today starts "tube bumper/hitch day"...
First thing we'll do is fab the brackets that bolt onto the frame. I haven't decided on how I'll terminate the main tube ends, straight and capped, or run the tube out a bit with a small raduis bent in to run around the rear fenders...
The main tube will be either 2" or 1.750" .120" DOM...we have both...
New situation... I'm have some door damage repaired which in this case means painting to match, SOOO....this seemed like a good time to throw on some front glass and have them painted at the same time...you know to save some money...
My first pick for the fenders are IconDynamic FRP's....Seeking comments on fenders....
Couple of frame rack shots...
Born 9/2004
2002 Honda XR650R
Old 08-08-2009, 05:18 PM   #1529 (permalink)
blk04titan's Avatar
ill put mine up to when I get it back from dmz
blk04titan is online now   Reply With Quote
Old 08-08-2009, 05:28 PM   #1530 (permalink)
06_SMOKE_SE_CC's Avatar
hey lou, how did you bend your frame, or did i miss a thread where you explained?
also, if it were me, i would run the bumper around the rear fenders, if it were me....
and i say go for the frp's....
i'm a one man wolf pack....
MODS DONE:
cst 4" spindles, radflo 2.0 coilovers w/3" preload, deaver c-30 spring pack, sway-a-way piggybacks, aem bruteforce w/dryflow, cherry bomb extreme muffler, t-rex billet upper grille, 35" hankook dynapro mt's, truxport tonneau cover, pioneer avic-n2 nav unit with ipod integration, pacific audio steering wheel control adaptor, smittybilt sure step black side steps, DDM Tuning 55w 6000k HID lows
MODS WANTED:
prg mt kit, giant springunder conversion, atx mojave teflons, frp fenders, trutrac with 4.11's, mag hytec diff cover
06_SMOKE_SE_CC is offline   Reply With Quote
Tags
007 dry humps prerunners, hooli motorboats bechlyf, tmoses wants some mid, travel in his rear, what the f u c k
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
PRERUNNER GREG 2.5" LIFT INSTALLED!!! hkusp45 Titan Performance Modifications 18 07-08-2008 06:45 PM
Towing In "D" versus "4th" Gear w/Tow Mode sculver Titan Towing & Hauling 24 06-06-2007 08:30 PM
Titan's "day at the spa" Howie Kaluha Titan General Discussion 10 07-22-2006 09:20 AM
"tall" camper shell or "light" trailer? pluckyew Titan General Discussion 7 01-06-2006 11:59 PM
Titan's Full Throttle "Lag" ??? pilot4net Titan General Discussion 9 10-27-2004 08:21 PM
