LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 02-19-2008, 07:39 AM   #106 (permalink)
Fox Delta's Avatar
Re: "Prerunner" Titan's
Originally Posted by hooligan
sweet! looking forward to the swag and decals!
we can get this thread on track just by posting a pic of a titan in prerunner form.
that is sweet - makes me want to go cut my bumper up!
2004 XE 4x4 CC OR
6" Pro Comp lift with SAW's
Deaver Springs in the Back with Bilsteins - thanks PRG!!
Bumpin Sub box and Sundown Amp thru Tech12Volts!!!
37x13.50/17 Toyo M/Ton Factory OR wheels
Cherry Bomb Extreme Exhaust
Fox Delta is online now   Reply With Quote
Old 02-19-2008, 07:45 AM   #107 (permalink)
54warrior's Avatar
How do I go about getting a Deaththreat Clothing Inc. T-shirt??? Got a 2XLT??
2005 Nissan Titan CC SE 4x4
Old 02-19-2008, 07:47 AM   #108 (permalink)
DeadRiver's Avatar
Send a message via AIM to DeadRiver
^^I think that truck would give Darth Vadar a boner. It's just sick...
2004 Sedona Titan LE CC 4wd
Link to DeadRivers' Overhead Racks with Bed Extender MOD Link to DeadRivers Titan Photos
2° | Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | 10" BA Sub in a www.tech12volts.com Enclosure
The Urinator™
DeadRiver is offline   Reply With Quote
Old 02-19-2008, 07:49 AM   #109 (permalink)
DeadRiver's Avatar
I meant to google for the website, i got this: http://search.ebay.com/death-threat
but that is definitely unrelated merch.
The Urinator™
Old 02-19-2008, 08:21 AM   #110 (permalink)
jasonmotox's Avatar
forgive my ignorance but, how are the bedsides "pulled"?
edit: nevermind, Hooligan answered by resurfacing the "Pulling bedsides" thread.
That black truck is sweeeeeeet!
[IMG][/IMG]
07' Osceola Swamp Runner
jasonmotox is offline   Reply With Quote
Old 02-19-2008, 08:42 AM   #111 (permalink)
hooligan's Avatar
difficulty level depends on the individual but i'm not tackling this on myself.
*just an example of what's involved*
Re: Pulling Bedsides
Its pretty easy.
Tools needed:
Body saw or air knibbler
riveter
Socket to remove stock bes supports and gas filler tube
6 inch by 18 inch peice of thin sheet aluminum
Screw type jack
8 inch long 2x4
48 inch 1/2 inch mild steel or galvanized tube
1.Pull your wheel and tire off to gain a little more access to the wheel well. Cut the stock bed support plate in half and unbolt the gas filler plate and bed support struts.
2.Place a screw type jack that comes with your truck against the inner fender well and place the 2x4 on the head of the jack and jack until the jack holds it against the lower lip of the bedside and enough pressure to hold the jack in place.
3.Put your wheel back on and slowly crank the jack until you reach the flare you want. Always watch for creases starting. You dont want to crease.
4.Measure the gap where you cut earlier. Shouldnt be any more than 2 inches. Cut the plate of aluminum 2 inches wider than your measurement.
5.Place the plate in the wheel well and drill holes through the plate and the stock plate you cut earlier all the way across the plate.Rivet in all the holes you drilled.As long as you riveted everything in you can take the jack out.
6. Now onto the bed struts you removed earlier. Pull the fender out by hand where you want it and have your buddy measure the distance from the stock mount on the bed to the mount on the bedside.Cut the tube you have about 2 inches longer than the measurement your buddy took. Stick 7/8 of an inch of the end of the tube into a vice and bend to the right mounting angle and drill a hole in it for the bolt. Or if you have a welder you know what to do. You should be able to use the stock rear strut if you bend it a little bit.
7. Bolt the gas filler back in place and viola! your done with the driver side. Now repeat on the passenger side.
born 12/3, purchased 1/4 '04 Smoke SE KC PRG MT kit, CST spindles, PRG Spec'd SAWs 2.5" C/Os w/Eibachs, SAW Airbumps, Deaver 3" springpack, PRG 1" billet blocks, Radflo 2.0 remote res shocks, PRG shackles, CST carrier bearing, PRG Offroad traction bars, 37x12.5x17 BFG All-Terrains, American Racing Mojave Teflons, 35w DDM HID low beams, SpinTech Pro Street custom exhaust, AEM CAI w/DryFlow Filter, IonicDynamics FRP prerunner fenders, front windshield tinted, Optima Yellow Top, Pioneer AVH-4100DVD w/ipod adapter connected to 160gb iPod, Sirius, HD radio tuner, Hertz 6.5" Components front, Boston 6.5" rear, Boston G1 10" subs, tech12 sub enclosure, Alpine amps, Eclipse BEC106 backup camera, TrueTrac, regeared from 2.94s to 4.11s...
>>>>>>>> Lucerne Valley offroad HD videos: http://vimeo.com/groups/h00ligan/videos
>>>>>>>> Lucerne Valley offroad PICS at: www.liftedimports.com
Old 02-19-2008, 08:51 AM   #112 (permalink)
MXtitan24's Avatar
black titans are dope.
black on black on black
murdered outt
MXtitan24 is offline   Reply With Quote
Old 02-19-2008, 09:31 AM   #113 (permalink)
06_SMOKE_SE_CC's Avatar
hey 54 and deadriver, send me a pm about the shirts, i don't wanna say anything on here that will get me in trouble with the mods, so pm me and i can give you the info on the shirts, plus i don't wanna hijack this thread anymore than i have, i hate when people do that...
once again, sorry a.i.i., and anyone else who's checking this thread out...
i'm a one man wolf pack....
MODS DONE:
cst 4" spindles, radflo 2.0 coilovers w/3" preload, deaver c-30 spring pack, sway-a-way piggybacks, aem bruteforce w/dryflow, cherry bomb extreme muffler, t-rex billet upper grille, 35" hankook dynapro mt's, truxport tonneau cover, pioneer avic-n2 nav unit with ipod integration, pacific audio steering wheel control adaptor, smittybilt sure step black side steps, DDM Tuning 55w 6000k HID lows
MODS WANTED:
prg mt kit, giant springunder conversion, atx mojave teflons, frp fenders, trutrac with 4.11's, mag hytec diff cover
06_SMOKE_SE_CC is offline   Reply With Quote
Old 02-19-2008, 07:34 PM   #114 (permalink)
loufish's Avatar
Its pretty easy.
Tools needed:
riveter
Screw type jack
8 inch long 2x4
If only it was so easy when you have the side storage box...I don't want to lose my box, I like my box....
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 02-19-2008, 07:50 PM   #115 (permalink)
MXtitan24's Avatar
keep your box
and be jealous of my pulled bedsides
anyone know who owns that black titan
the more i look at it the more i fall in love with it
also if anyone knows about that front bumper,
he just cut the end caps right?
because a set of those are $44 a piece on ebay
and that would easily be the best $88 + S&H i will ever spend on my truck
Old 02-19-2008, 08:54 PM   #116 (permalink)
Banned
VTECLESS's Avatar
This is the NCD 4wd LT kit owned by a guy in Camarillo, CA. Has been for sale for a little while. It is awesome. More pics on NCD's myspace. NCD Customs. He removed the end caps and cut the center.
prerunner-titans-dave.jpg  prerunner-titans-dave2.jpg  prerunner-titans-dave-3.jpg  prerunner-titans-dave4.jpg
VTECLESS is offline   Reply With Quote
Old 02-19-2008, 09:04 PM   #117 (permalink)
A.I.I.Raciing's Avatar
I gotta say, I'm very suprised that this thread has already gotten 3300 hits with 115 post. I really didnt expect to get more than 4-5 replies. I'm glad to see it getting so much attention.
I know there was someone on here that worked for Bob Graham, if that person reads this, would you please PM me, I have a question about a sticker on the Titan
A.I.I.Raciing is offline   Reply With Quote
Old 02-19-2008, 09:05 PM   #118 (permalink)
MXtitan24's Avatar
ayy thanks alot!
that will be coming soon to my truck
im searching ebay for a new center to cut up as we speak
Old 02-19-2008, 09:09 PM   #119 (permalink)
Banned
VTECLESS's Avatar
Originally Posted by MXtitan24
ayy thanks alot!
Looks EVIL!! I love it.
Old 02-19-2008, 09:20 PM   #120 (permalink)
Banned
VTECLESS's Avatar
You can check out Bob Graham's "new build" at the Offroad Impact Show
March 6-8 in Anaheim. Features this truck with the new NCD upper J-arm. Gonna be SIK.
I believe it's this truck, but BLACK.
Tags
007 dry humps prerunners, hooli motorboats bechlyf, tmoses wants some mid, travel in his rear, what the f u c k
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
MXtitan822
PRERUNNER GREG 2.5" LIFT INSTALLED!!! hkusp45 Titan Performance Modifications 18 07-08-2008 06:45 PM
Towing In "D" versus "4th" Gear w/Tow Mode sculver Titan Towing & Hauling 24 06-06-2007 08:30 PM
Titan's "day at the spa" Howie Kaluha Titan General Discussion 10 07-22-2006 09:20 AM
"tall" camper shell or "light" trailer? pluckyew Titan General Discussion 7 01-06-2006 11:59 PM
Titan's Full Throttle "Lag" ??? pilot4net Titan General Discussion 9 10-27-2004 08:21 PM
