I was wondering if that was the same truck, is the titan on that same mag a member here....?
My room mate just brought that off road mag home last week and 2 days ago the same Titan in the magazine pulled up next to me at a stop light! I talked to him for like 30 seconds then the light turned green. Hes claiming 16" in the front. I've never heard of a PRG kit cycling that much.
You clearance the inner fender and strategically install a 10" travel shock and WALA! up to 17" I hear You can only droop so much then things start to bind. So it comes from more bump.
11" of travel and an orange piece of tape on the steering wheel.
They slap on the name raptor and every kid and their mother wants one. Nissan doesnt do it cause they wont think there are people stupid enough to buy it. dam ford is a miracle worker hahaha
Ride in one and you will be stunned. Plus with some simple work like a shock hoop and it will pull 15.
Rebar Wrangler
So in order for you to get that much would you have to get a taller shock hoop or would the on you are currently running still work? Also what are you running in the back. I just have the C30 Deaver pack with no block and I'm gonna get 37 BFG AT's. They are 36.6" tall. Are they gonna rub when I bottom out? I know Hooli is running them but he has a 1 inch block I thought.
with bedsides you can run any size tire your little heart desires.
I think the front shock would have to be mounted a little higher up.
I also have the C30 with no blocks, PRG shackles and 2.5 Radflo emulsion.
The 37" BFG AT's run smaller than MT's so they will be fine.
Not in the front, with the wider tracking width I would have to cut up the front glass to get more bump or get the Perrys front piece.
