User Name
Password
Need Help!! Leveling Kit Making Noise - being discussed at Nissan Titan Forums in the Titan Suspension section.
Old 02-11-2008, 05:19 PM   #1
n8dooling
n8dooling's Avatar
I Just Installed My 2" Leveling Kit From Ncd And 1" Blocks In The Rear And Got It Aligned But Am Dealing With Clunking Noise Coming From The Front End (its More Noticeable Over Smaller Bumps). I Just Went Back And Checked All The Bolts To See If They Were Lose But Everything Was Tight. I Am Feeling It More In The Floorboard And In The Pedals More Than A Distinct Clunking Noise It Sounds Like Something Is Loose. Could The Shock Be Bad? What Noise Does A Bad Shock Make? They Are Rancho. Thanks Any Help Is Appreciated.
n8dooling is offline   Reply With Quote
Old 02-13-2008, 07:39 PM   #2
Jared
Send a message via AIM to Jared
Re: Need Help!! Leveling Kit Making Noise
not sure on yours, but my level kit allows the upper control arm to contact the upper spring perch when the front suspension is at full hang. i hear that at times.
MY06 Smoke Titan SE CC 4x4 Tow
Nismo Cold Air, Banks Monster, Nismo Headers,
2.5" leveler
ASE Master Technician
Nissan Master Technician
AEM Trained
Jared is offline   Reply With Quote
Old 02-13-2008, 10:19 PM   #3
Titan460
Titan460's Avatar
Big pain in the rear but you could take the spacers out and see if the sound is still there.
Titan460 is offline   Reply With Quote
Old 02-13-2008, 10:37 PM   #4
Yellomantis
Yellomantis's Avatar
Did you install taller bump stops as well? Also, take a look at your coil buckets, your upper control arm might be hitting as well.
www.myspace.com/yellomantis
Yellomantis is online now   Reply With Quote
Old 02-14-2008, 09:28 AM   #5
husker1206
husker1206's Avatar
Make sure you got your sway-bar link tight. I had the same clucking noise when I went over bumps.
2005 CC LE 4x4: 2" leveling kit
35-12.50-18, Nitto Mud Grapplers
Volant CAI, Helix TBS, 2* Advance
Borla Dual Exhaust
husker1206 is offline   Reply With Quote
Old 02-14-2008, 09:48 AM   #6
Arachnid
Arachnid's Avatar
Something has to be loose or installed incorrectly. I just installed the PRG level kit and it makes zero noise.
AKA: Critter Whore™
Arachnid is online now   Reply With Quote
Old 03-02-2008, 09:40 AM   #7
n8dooling
n8dooling's Avatar
I got it FIXED!!!!! It was a bad shock piece of S*@! Rancho's put Bilstein HD's on front and rear very pleased Thanks to NCD and PRG for the input those guys know what's up!!!
User Name
Password
pro comp lift making noise helix139 Titan Suspension 9 05-13-2008 03:52 PM
extended brakelines possibly making noise AETitan Titan Suspension 1 01-04-2007 07:11 AM
Brakes making a noise after rim replacement TitanConvert21 Titan Wheels, Tires & Brakes 15 04-05-2006 12:18 PM
rear diff making noise abmobil Titan Engine, Transmission & Drivetrain 0 03-21-2006 10:08 PM
Window making a knocking noise when lowered BLoch Titan Problems & Dealer Service 4 08-03-2005 04:03 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
