I've had my PRG performance kit for several months and finally after hunting season, got around to putting it on. I have the SAW's with the PRG upper control arms and the recommended by Greg himself 1" block for the rear. The kit is top notch I must say no problems with anything, all 3/8" hand tools used. It was all I had in metric, of course if you know how to apply leverage with other wrenches it will all work. And I did everything by myself. So it can easily be handled by one person. The only thing I'm dissastified with is the bolt that goes thru the UCA (ball joint end) it's a little too short to get full thread and activate the plastic piece of the lock nut. Tommorrow the front end alignment and the 315's go on. Then I will fine tune the ride height and do the pinch weld mod this weekend. Two unusally things to note: the fake OR Rancho's on the rear are still in good shape, and the BFG Rugged Trails have made it to 40K, could push it futher.. but nope, I 'm ready for some bigger rubber. Will have to post up some pictures when all is completed and it's good and clean.
2004 Titan LE CC 4X4 Offroad Blizzard
Amsoil 5W30, Amsoil 75W140 Severe Gear
PRG Performance kit and BFG 315/70/17 All Terrain TA KO's
PRG Shackles
2004 Nissan Altima 2.5SL
2004 Polaris Sportsman 500 Camo W/Winch
Brother what will-power you must have!
I think I took a day off work to install my kit as soon as I got it!
PRG Performance Kit w/SAW's
Born 9/2004
I'm in the same boat. I got my stuff today and can't wait for the install. I think I can handle the install my self.
2007 SE Granite C/C 4X4 BT,OR,RF,Bed Package
Born 12/18/06 in Mississippi/ adopted 03/31/07 in Anchorage. Man that stork had a good drive.
Improved with Westin black aluminum nerf bars, Husky floor liners, Vent visors, Full billett grill, Black XE door handles,American racing Teflon THUG'S, Top Dawg folding tonneau cover, AEM brute force CAI with prefilter,
PRG 4INCH PERF Package with Saw's Shift Pass You
We want pictures! It's true, no matter how many people get the PRG package (and we all know what it will look like on the Titan), we always want the pictures to see it anyway.
__________________ 2006 XE KC 4x4, Galaxy Black
Preferred Package, OEM Bug Deflector
Sirius Satellite Radio / IPOD (Plug in kits)
AMSoil 5W-30XL Synth. Motor Oil, OEM Oil Filter
AMSoil Drop in dry air filter/Air Box Mod
AMSoil 75W-140 Severe Gear Rear Diff Fluid
Mobil 1 75W-90 Synthetic Front Diff Fluid
Toyo Open Country AT's P265/70/17
Well its about time you got around to putting that package on. Hell, you ordered yours the same day I ordered mine from him...back in October/November. You must have some willpower to have waited this long. I'm glad you finally got around to putting it together.
P.S. Did you have the clunking sound on your coilovers? I know a couple of us bought them around the same time and have had problems with the infamous sound. Also, be sure to post pictures of your truck. (I'll put pictures up of mine once I find a damn camera I can use. )
285/70/17 BFGoodrich All-Terrain T/A KO
DIY Air Box Mod w/ Drop in AMSOIL EaA Air Filter
TomTom One XL Navigation
2* Timing Advance
PRG Shackles (Still need to install these...)
Some UCA's went out with the shorter bolt for the Frontier/Xterra UCA's. Call me 951 780-5331 and ill send you the proper lenght bolts and new nuts. i wont be in today, so shoot pm a pm or leave a message.
No clunking noise, I'm so glad, haven't driven it alot yet but so far so good! They just called saying my front end is aligned and tires are on. Can't wait to see how it drives and rides now. BTW does you steering wheel lock know? That appears to be off now.
PRG Shackles
Yeah, my steering wheel still locks. I don't know why that would go away with yours? Did you get the rear DRs or the SAWs?
2* Timing Advance
..... The only thing I'm dissastified with is the bolt that goes thru the UCA (ball joint end) it's a little too short to get full thread and activate the plastic piece of the lock nut. ....
Personally, I would use some of the blue Permatex Threadlocker on that if you haven't already just to be on the safe side. I used it on my mini-lift because it'd be a b**** to have something come loose while out in a field somewhere.
__________________ 2005 Armada LE 4x4 - 2* Timing Advance - AirBox Mod - PRG Mini-Lift - Nitto TerraGrapplers 325/60-18
_____________
. Check out my Gallery! .
