Old 02-22-2008, 05:38 PM   #1 (permalink)
roy365's Avatar
Adding Drop With Existing Mods?????
In the market for the McGaughys 2/3 drop kit. I am wondering if anyone that has dropped their Titan with mods like exhaust, sway bar, etc.......had any issues when installing the drop kit later? Hopefully nothing would need to be taken off besides the obvious suspension parts needed. But, i'm not much of a visionary and sometimes miss small details that lead to bigger headaches. If any of you that have dropped your Titan with the mentioned kit could give me some feedback it would be greatly appreciated. Kinda late to be calling them right now.
0-60MPH@5.82 & 1/4 mile@14.25 Passport GT Timer
Mods list: http://www.titantalk.com/forums/memb...ml#vmessage205
roy365 is offline   Reply With Quote
Old 02-26-2008, 06:44 PM   #2 (permalink)
Re: Adding Drop With Existing Mods?????
I was in the same predicament. I installed my exhaust when I bought the truck (2005). The exhaust shop asked me if I was going to drop the truck in the future, cause if I was they recommended me not doing the exhaust until after the drop because the pipes might rub against brake lines, etc. I installed the McGaughys last week. What a big difference in stance and looks. Luckily the pipes, especially the ones over the axle does not touch any lines. You can actually measure yourself with a tape measure to see if you will cause any interference. The 2/3 drop is not that drastic of a drop so I was okay, luckily.
olavere808 is offline   Reply With Quote
Pre-existing wiring TiTan Drivan Titan Visual & Audio Discussion 2 03-07-2007 05:52 PM
Does adding performance mods void warranty? germangrunge Titan Performance Modifications 5 10-22-2006 09:06 AM
TrueTrac install uncovered existing problem... GotMyTruck! Titan Engine, Transmission & Drivetrain 27 09-05-2006 06:05 AM
Title Transfers on used car with existing loan? fellowx Off-Topic Discussion 1 06-11-2005 01:00 AM
