Old 02-22-2008, 06:11 PM   #1 (permalink)
MXtitan24's Avatar
Deaver 4-5" Race Spring
my coilover racerunner is amazing (to me) i can hit bumps and assorted obstacles at 50+ with very little affect, but my rear (bilstein or a radflo dont remember) is really really lacking in that what ever i hit, it hits hard. hit a bump so hard it turned on my windshield wipers. so i was wondering what i could do to fix it? maybe DEAVER 4-5" RACE SPRING?
>2004 SE Charcoal/Smoke/Gray CC
-FLowmaster 40 Series
-Two 12" Rockford Fosgate Punches
-Crossfire Amp
-Self Built Fiberglass Box
-Clarion In-Dash TV
-Debaged
-5% Tint so you can't see up in my windows
-RaceRunner Coilover
-CST Spindle (7.5 up front)
-Bilsteins & a Block in the Rear (3 in the back)
-Dual PRG Stickers
>CRF 450
>CRF 250
>2004 Nissan Frontier 4x4
>1960 Rag Top Bug
>1959 Euro Rag Top Bug
>1967 VW Baja Bug
MXtitan24 is offline   Reply With Quote
Old 02-22-2008, 06:25 PM   #2 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Re: Deaver 4-5" Race Spring
Call me for the scoop on the springs. Although they can work well, you need more shock for your driving style. To get the spring to work right you will need to run a longer shackle and to move the rear spring hanger. Deaver alos has a new spring under set-up. Do you plan on running the shocks through the bed?
Old 02-22-2008, 06:29 PM   #3 (permalink)
BECHLYF's Avatar
Please explain further.
Old 02-22-2008, 07:18 PM   #4 (permalink)
BECHLYF's Avatar
Hi MX, I was wondering the same thing and posted a reply to Greg. And when he didn't reply (I got a little inpatient) I called and he said he thought you where initially talking about the DEAVER 4-5" RACE SPRING. SO with that said I ask before I put on these new shackles you just sent me can I get better performance by installing a longer shackle and relocating the mount? He said no, I thought he was talking about the DEAVER 4-5" RACE SPRING. If you want to hit it harder let me re valve your Radflow's . And I said OK. So MX what spring and shock set up do you have? do still have the overload spring?
-Crossfire Amp
-Clarion In-Dash TV
-Debaged
-Dual PRG Stickers
OK here's the problem, Lose the block's overload springs and the Bilsteins, then install the Deaver mini pack and a Radflow or Saw-A-Way shock (rebuild-able and custom valve-able) and the PRG HD SHACKLES. Thats the next step to P-L-U-S-H in the back.
Old 02-23-2008, 04:32 AM   #5 (permalink)
My reply was strictly speaking of the Deaver 4-5" race spring. Not our mini-packs.
Old 02-23-2008, 08:58 AM   #6 (permalink)
MXtitan24's Avatar
I'm not cutting holes in my bed because i don't off-road enough to justify losing space in my bed for my dirt bikes. I was just curious as to what i should to make my rear as plush as my front and gain some height (because i plan on going higher in the front as well) sounds like the answer would be "install the Deaver mini pack and a Radflow or Saw-A-Way shock (rebuild-able and custom valve-able) and the PRG HD SHACKLES."
now that sounds good and all but how high would that put me up in the air?
-Crossfire Amp
-Clarion In-Dash TV
-Debaged
-Dual PRG Stickers
>CRF 450
>CRF 250
>1960 Rag Top Bug
>1967 VW Baja Bug
Old 02-23-2008, 09:21 AM   #7 (permalink)
BECHLYF's Avatar
About 2" if you want to go higher then you will have to use blocks and the drive shaft carrier drop down bracket. With tubular A-arms you can adjust your SAW's for more lift then choose what thickness of block to gain your preferred stance.(height in the rear)
Pic below is with Deaver mini pack and 2" blocks and carrier drop down bracket
Old 02-23-2008, 09:26 AM   #8 (permalink)
MXtitan24's Avatar
what is a tubular A-arm? i have never heard of this before
and this is the height i want:
-Crossfire Amp
-Clarion In-Dash TV
-Debaged
-Dual PRG Stickers
>CRF 450
>CRF 250
>1960 Rag Top Bug
>1967 VW Baja Bug
Old 02-23-2008, 09:33 AM   #9 (permalink)
BECHLYF's Avatar
That lift is done with with Tubular A-arm's , 4" spindles and Donahoe racing coilover with a flipped top mount, Deaver spring pack and a block ( what size?) call Greg.
Tubluar A-arms: A-arms made from tubing.
Old 02-23-2008, 09:58 AM   #10 (permalink)
MXtitan24's Avatar
That lift is done with with Tubular A-arm's , 4' spindles and Donahoe racing coilover with a flipped top mount, Deaver spring pack and a block ( what size?) call Greg.
you are the first person that can actually answer my questions
so i have more for you
-how much are tubular A-Arms
-can i use my Race Runner instead of a Donahoe
-what is a flipped top mount
-and what Deaver spring pack, there are 3 or 4 choices i believe
-Crossfire Amp
-Clarion In-Dash TV
-Debaged
-Dual PRG Stickers
>CRF 450
>CRF 250
>1960 Rag Top Bug
>1967 VW Baja Bug
Old 02-23-2008, 12:11 PM   #11 (permalink)
-A-Arms: $450-$650 Camburg, Total Chaos, NCD and PRG's
-Yes, SAW's can be used. FYI, the SAW's (depending on which SAW's you have) are
1" longer than the DR's.
-The DR's come with a mounting bracket on top if the shock. You can flip the mount up side down which will give you about an extra 1.5" lift.
-Deaver Spring Pack? I don't know.
splifrover is online now   Reply With Quote
Old 02-23-2008, 04:23 PM   #12 (permalink)
hooligan's Avatar
good job splif...
deaver spring pack from greg's site: prgproducts.com
DEAVER 1.5" MINI PACK
This leaf spring pack is manufactured exclusively for us to our specification. It gives you approximately 1.50" of lift and can be used with rear blocks for added lift. The Deavers lessen axle wrap and greatly improve the ride of your Titan. Typically, longer shocks are required. We recommend the Bilstein rear replacement shocks sold right here on PRGproducts.Com! Click here to see a comparison of the Deaver Mini Pack to the stock spring.
$219 - FREE SHIPPING
DEAVER 2.5" MINI PACK
Similar to the 1" and 1.5" mini packs, this is a 3-leaf spring pack that mounts in place of the overload leaf, but provides approx 2.5" of lift and a bit firmer ride with greater load capacity over the 1" and 1.5" packs.
The DEAVER 4-5" RACE SPRING is a race-style complete spring pack that offers approx 5" of rear lift. It has a military wrap front eye and offers a race-inspired ride. Our experience shows that a heavy-duty shackle should be run with these springs as the stock shackles tend to fail due to the higher spring rate.
$649 plus shipping (shipping based on weight and your location – actual shipping, no handling fees – we will bill you for shipping charges prior to your order leaving – you may call for a quote)
Old 02-23-2008, 06:22 PM   #13 (permalink)
MXtitan24's Avatar
damn.. so im basically at another 1,000 bucks..
3rd time lol
thanks for all the help guys
-Crossfire Amp
-Clarion In-Dash TV
-Debaged
-Dual PRG Stickers
>CRF 450
>CRF 250
>1960 Rag Top Bug
>1967 VW Baja Bug
Deaver 1" Mini Leaf Spring Question senna1 Titan Suspension 6 10-11-2007 06:12 PM
FS: Deaver 2 1/2" spring pack $100 djalex Buy/Sell 27 09-16-2007 09:23 AM
Brand new Deaver 2.5 Spring pack $195 shipped RedHotTitan Buy/Sell 4 06-12-2007 08:05 PM
deaver 2.5" springs AETitan Titan Suspension 1 04-11-2007 09:05 PM
Total Chaos Shackles & Deaver 1" spring pack bestatchess Prerunners.com - Titan Leveling Kits 4 12-11-2006 06:50 PM
