Thanks for the post about grinding the tabs but I wish you would have said something about the upper bolt. Or am I the only big dummy that thought it would be better to install them from the outside only to find it is too long and would hit the frame.
06 SMOKE SE KC 2WD TITAN /AEM INTAKE/FLOWMASTER 40/2*TIMING ADVANCE/CST 4" LIFT SPINDLES/DONAHOE COILOVERS W/ 5/8" SPACER/TC A-ARMS/DEAVER 2.5 MINI PACK/PRG OFF ROAD TRACTION BARS/RADFLOW REAR SHOCKS/ CST CARRIER DROP/PRG HD SHACKELS/OEM CHARCOAL 5 SPOKES/35X12.50R18 HANKOOK DYNAPRO MT/HOOPERS CUSTOM 3.73 GEAR INSTALL W/TRUETRAC AND MAG-HYTECH DIFF.COVER
Looks good. Thanks for the pictures. The only thing stopping me from buying the PRG shackles is a question about the shackle bushings. Do they seem to be the same quality as the OEM shackle?
at least! lol .... he looks a little nose-high though, figured he want to lower front a bit, you know, for the lower COG
The lower I can make it the better, Go's along with the lighter I can make it,The more torque and traction I can make,The more travel I can get etc....BUT better nose high than raked.
Hey BECHLYE, I really appreciate the detailed pics and instructions. I've been thinking about doing this since Greg posted about these adj. shackles. You've given me the courage and taken out the guess work to do it myself. Thanks bro'.
Nice stance on your baby by the way.
L
You are very welcome, and thats why I posted. Its good to know before you GO!
I thought that was too obvious so didn't want to seem condisending.
Thanks Bechlyf.
I just did mine.
Here are some pics of the tools I used.
One is a 1/4 drive setup that I used to undo the toolbox bolts.
I didn't remove the whole box. I just undid it and let if flop out of my way for clearance.
My truck has almost nothing compared to some of you guys, but I still like it.
Thanks Bechlyf.
I just did mine.
Pneumatic tools, nice. I have a 6 gal.pancake compressor, would that do the trick?
I seriously doubt it.....
Not enough volume in those small tanks .....
I tried it with my pancake on my wheels but it would not break the lugs loose..
It did good running the lugs on but i still had to hand torque the lugs down...
