4wd coils are a stiffer by about 100lbs/in. but not longer. But the 2 on 4wd '08 the coils are longer than previous years...but the same spring rate (except for the 4wd longbed, which is stiffer).
Greg, are you saying on the '08 trucks the 2wd and 4wd coils have the same spring rate, but the 4wd spring has more free height? Or are you saying the '08 4wd coil has the same rate as previous years 4wd coil but has more free height?
my friend has a fairly new set of titan 4wd coils ,so i was just wondering if there would be a better diffrence if i changed my 2wd ones out for the 4wd ones maybe a stiffer ride i think the ones i have now are kinda soft i would like it a little more stiffer ,coil over would be my best bet but those gotta wait for now
+1 to that. I think Greg had mentioned this would work as you are thinking. If not he makes a nice coil over setup.
yea i know the coilovers are the way to go cant afford them yet ,, just tryin to see if adding the 4wd spring would be worth it, if u can actually tell ride diffrence like i said springs im getting free just trying to make it better till i get coilovers
Not worth the work IMHO...4WD still has crappy stock shocks...maybe bilsteins...they go for under a 100 each.
2005 CC 4x4 SE
AKA
ChunkyAssWhore™
All Time Favorite TitanTalk Quote (in response to what type of Gasoline is best):
I personally prefer whatever's cheap. I'd club baby seals to death and squeeze oil from their limp little bodies if I could save a buck - Mr B
well i have brand new bilestins i havent installed them yet i was just gonna put the 4wd drive springs on them instead of my 2wd springs and see if there was a diffrence
