Re: prg leveling kit?
Basically removing the strut, grind a little off the coil bucket(for upper a-arm clearance), put the spacer on the strut, & reinstall. Be careful not to pull on the brake and ABS lines, or the axle out(if 4wd). Unbolt the sway bar links 1st & reattach last.
If not equipped with alignment cams(offset lower a-arm bolts/washers), now would be an easy time to swap those too.
I know they're not always needed, but I believe in preventive maintenance.
Have it aligned, & recheck all bolts in about a week.
