I have a 2wd 06 titan and plan on a lift, but don't want to change wheels right now so that through the cst spindle out, and i'm thinking of coilovers, if I buy a coilover that gives 3-4" cranked all the way up and a 3" leveling kit, wouldn't that be around 6 inches of lift or so? I'm new to the Titan Suspenion and parts since I've never owned one just a chevy. Thanks
You can run the CST spindle with stock wheels as long as you don't go with a crazy mud tire with large sidewall lugs, i.e. Nitto Mud Grapplers. The lugs will rub the spindle. A 'normal', less aggressive tire will be fine.
Well im going to run all terrains but the man i talked to on the phone said it would rub the stock rubber on the tire and wheel spacers or new wheels were needed maybe i shouldnt have listened to him, thanks, anybody know on the lift or so?
I have the CST spindles, 295/70 Nitto T/G's and the factory Off-Road wheels, and it comes close, but it does clear...
PRG Performance Kit w/SAW's
Born 9/2004
