Old 03-05-2008, 03:18 PM   #1 (permalink)
mr.cash's Avatar
prg leveling kit question
if i install the 4x4 leveling kit for the front do i have to get my tires balanced or anything like that? or is it bolt on and ready to go?
mr.cash is offline   Reply With Quote
Old 03-05-2008, 03:47 PM   #2 (permalink)
Rolex's Avatar
Re: prg leveling kit question
You shouldn't need the tires balanced unless they're already out of balance. I think it's recommended that you get the front end aligned to prevent uneven tire wear.
My BIL is a service manager and told me I should ask for the following to be installed (per a service bulletin) after I install the PRG leveling kit:
Cam Bolt - 54580-7S005 Qty. 4
Cam Washer (Eccentric) - 54559-7S005 Qty. 4
Expecting the world to treat you fairly because you are good is like expecting the bull not to charge because you are a vegetarian.
Rolex is offline   Reply With Quote
Old 03-05-2008, 04:06 PM   #3 (permalink)
mr.cash's Avatar
what do u mean by the service bulletin?
Old 03-05-2008, 04:27 PM   #4 (permalink)
54warrior's Avatar
Some late 2005 models, all of 2006 and 2007 had bolts that attach the lower control arms to the frame which provide ZERO adjustment for the camber. All the rest came with "cam" bolts so that the camber can be adjusted. If you have a 'regular' style of bolt, you'll need the camber style bolts.
Read through this:
Allignments, Camber Bolts, & Leveling Kits
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government. - Thomas Jefferson
Old 03-05-2008, 10:54 PM   #5 (permalink)
Schrute's Avatar
My 08 did not come with the cam bolts. I thought I would need them to get the alignment back in spec after installing the leveling kit, but my tire shop was able to get the everything back within spec without the bolts.
On the other hand, if you can get your dealer to provide the bolts at no cost per the service bulletin, that certainly wouldn't be a bad thing.
08 LE 4x4 Majestic Blue w/Tow. SAW C/O's (2.5" preload). PRG UCA's. PWM. Swaybar removed. SAW Piggybacks. Deaver C10 leaf pack (largest leaf removed). PRG Shackles (set at -1"). PRG OR Traction Bars. American Racing Motto MT100 20x8.5 chrome wheels. 35x12.50 Toyo M/T's. AEM Brute Force Intake. Nismo Exhaust. 2 Degree Advance. AMP Powersteps. Hella 500 driving lights. ScanGuageII. Debadged.
Schrute is offline   Reply With Quote
Old 03-06-2008, 05:07 AM   #6 (permalink)
Blackbeauty's Avatar
I put the camber bolts on when I installed my SAW's.. Turned out, I didn't really need to. Nothing was out but the toe....
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 03-06-2008, 06:01 AM   #7 (permalink)
Quartz's Avatar
A leveling kit will not affect the camber. You will have to have the toe in adjusted though.
Old 03-06-2008, 02:16 PM   #8 (permalink)
mr.cash's Avatar
i have an 04 am i going to be able to just bolt on and drive it?
Old 03-07-2008, 04:38 AM   #9 (permalink)
You can always just "bolt on and drive it". BUT, you're likely to kill your tires prematurely. Get it aligned afterwards.... The toe usually needs to be adjusted.... And tires get expensive.
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 03-07-2008, 02:29 PM   #10 (permalink)
mr.cash's Avatar
i dont know what cam bolts are please share
Old 03-07-2008, 04:25 PM   #11 (permalink)
Rolex's Avatar
This link is posted above.
CLICK ME!!!
leveling kit question 2007 TITAN LE Titan General Discussion 10 11-27-2007 06:18 PM
Leveling kit Question LpLove08 Titan Suspension 2 09-17-2006 03:04 PM
Question for those with PRG Leveling Kit socaldad Titan Suspension 15 05-26-2006 04:15 PM
Question about the need for a leveling kit archer75 Titan General Discussion 4 04-17-2006 11:29 AM
Leveling Question TDRaider Titan Suspension 10 12-31-2005 11:23 AM
