Old 03-07-2008, 12:05 PM   #1 (permalink)
eoc1212's Avatar
Installation questions...
Hi all,
I am preparing to install a set of Total Chaos UCA. Was wondering 2 things... insight from any DIY-ers who have done it would be awesome:
1. How long did both sides take you to do? (I have air tools)
2. I read the very helpful instructions and saw the image in the thread about installing the Total Chaos UCA... BUT this line confuses me:
you might be able to sweet talk the seller into installing the zirc(sp?) fittings for you. If you do not have a tap and die set this would be a great help to you.
What is this exactly (I don't have the parts in hand yet)? The Total Chaos arms don't come with this pre-assembled?
Any help would be appreciated!!! THANKS GUYS!!!
Edwin
eoc1212 is offline   Reply With Quote
Old 03-07-2008, 12:17 PM   #2 (permalink)
grnTitan04's Avatar
Re: Installation questions...
While I know nothing about your installation or parts, this should help you understand the butchered spelling you mention: Zerk Fitting
You need to create a threaded hole to insert the fitting, but I bet few people actually bother.
Improvements:
K&N Drop in, Magnaflow muffler, Step Tubes, Reese Hitch, Husky Liners, Nitto Terra Grapplers 285/70/17
Air Box mod, Improved Fog Light Mod, dba 4000 series rotors, Akebono ProACT pads, Extang RT Tonneau, RadFlo Remote Res Rears, OEM Hood Deflector
Wish List: Air Horn, RadFlo 2.0 Coilovers, AEM Brute Force CAI, TruTrac, Bass boat...
Donations graciously accepted.
grnTitan04 is offline   Reply With Quote
Old 03-08-2008, 06:22 PM   #3 (permalink)
Send a message via AIM to galaxycrew
i bought my arms from another member who already installed the zerk fittings...but i wouldnt suggest installing the arms without them. the bushings NEED to be lubed every now and again...having the zerk fittings in place will make the job a 2 min job....instead of 2 hour min.
galaxycrew is offline   Reply With Quote
Old 03-08-2008, 09:01 PM   #4 (permalink)
BECHLYF's Avatar
Originally Posted by eoc1212
Hi all,
Edwin
THE ZIRC fittings are the little fitting you use to grease the UCA bushings.and they come pre tapped ready to install, that must be old info.
Parts Included:
Upper A-Arms w/ Bushings & Inner Sleeves
Tapered Spindle Adapters & Grease Fittings
1" Uniballs & Retaining Clips
Grade 8 Hardware
installation-questions-total-chaos-uca.jpg  installation-questions-total-chaos-uca-installed.jpg
E&G Grille Installation Questions cswake Titan Parts & Accessories 8 06-15-2008 09:18 PM
Questions on new brake pad installation. jrein8383 Titan FAQ & Howto Area 8 10-04-2007 04:25 PM
OEM Brush Guard Installation Questions cmcadams Titan General Discussion 0 03-25-2007 07:08 PM
CB Installation Questions Beach-TJ Titan Visual & Audio Discussion 5 08-25-2006 12:49 AM
GPS Installation Jerrygfd Titan Interior Discussion 2 07-03-2006 02:06 PM
