Old 03-09-2008, 09:52 PM   #1 (permalink)
What will it take to clear 37's?
Im running the basic PC 6" right now with 33's but Im wanting to lift the truck up a little more. I was just going to get some 35's when these tires wear out but then I got to thinking what would I need to clear some 37's? I was thinking about just doing a 3" body lift but I feel like there has to be more options, I just dont know what they are??? So what parts would I need to get the truck up high enough to clear? Or should I just do a body lift, and would 9" be enough to clear 37's?
Sorry for all the question, I just want to make sure.
2007 Nissan Titan: Pro Comp Lift, 20" AR Rims, Pro Comp Tires, Nismo CAI, Nismo Exhaust
Other Cars/Bikes
2004 Mystichrome Cobra Coupe: (383 RWHP)
2000 Trans Am Ws6: Full Bolt On, Cammed, Sprayed, TH400 Tranny, Some Suspension work(563 RWHP/610 TQ)
2003 Honda CBR 600RR: Custom Paint, SS Brake Lines, GPR
2003 Honda CBR 954RR: Two Bros Pipe, GPR, Seat Cowl
TrevoRR is offline   Reply With Quote
Old 03-09-2008, 10:01 PM   #2 (permalink)
hooligan's Avatar
Re: What will it take to clear 37's?
- pinch weld mod
- Ionicdynamics.com FRP prerunner fenders
- prerunner bumper
Old 03-09-2008, 10:02 PM   #3 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Check your rear blocks. I would swear that they are in backwards by how far back they are riding.
Old 03-09-2008, 10:34 PM   #4 (permalink)
are u talking about the lift blocks, how do u know what way they go ,and uf they go in wrong what happens
TITANS04 is offline   Reply With Quote
Old 03-09-2008, 10:51 PM   #5 (permalink)
hooligan's Avatar
yeah, he's talking about your blocks in the rear. it does appear the wheels sit a hair further back from where they're supposed to sit, but it could just be the pic. i'm guessing the blocks are tapered and if backwards could cause them to set the wheels back. just a guess.
Old 03-09-2008, 11:03 PM   #6 (permalink)
so if the block is just regular blocks non tapered u cant put them in wrong , and if there tapered u can put the angle in the wrong way and it shoves the wheel back just taking a guess
Old 03-10-2008, 04:06 PM   #7 (permalink)
yamatitan's Avatar
I thought the block that came with the procomp lift was not tapered? the ones that came with my procomp stage one were not tapered.
Procomp 6" ($1300.00)
35x12.5x18 Toyo MT's $1100.00)
PRG Offroad Traction Bars ($489.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
SAW coilovers ($1000.00)
Bushwacker Pocket style flares ($600.00)
Rear Sway-away piggybacks ($399)
Money wasted so far=$9073.00
Old 03-11-2008, 05:47 AM   #8 (permalink)
The block isnt tapered, but it does use an offset pin. It is designed to bring the wheels forward.
Old 03-11-2008, 06:05 AM   #9 (permalink)
Fox Delta's Avatar
so we can clear 37's with just the fenders and pinch weld mod? I would rather keep the truck as low as possible for center of gravity but i want 37's too
2004 XE 4x4 CC OR
6" Pro Comp lift with SAW's
Deaver Springs in the Back with Bilsteins - thanks PRG!!
Bumpin Sub box and Sundown Amp thru Tech12Volts!!!
33x12.50/17 Mickey Thompson MTZon Factory OR wheels
Cherry Bomb Extreme Exhaust
Fox Delta is offline   Reply With Quote
Old 03-11-2008, 11:12 AM   #10 (permalink)
Here you go Fox. You may have seen this shot before. But 37s with only 4-5" of lift.
Old 03-11-2008, 06:34 PM   #11 (permalink)
yamatitan's Avatar
I hope i have mine in the right way then. If i remeber correctly they have an arrow on them right?
Does this look right to you?
Old 03-16-2008, 04:23 AM   #12 (permalink)
Fox Delta's Avatar
thanks Greg! I needed that motivation.....
did you just cut the front fenders? I have pulled the plastic inner fender cover out to see... looks like I can get about 2-3" at the trailing edge of the front fender
2004 XE 4x4 CC OR
VK-Pro on 37's???? pgthe1 Titan Performance Modifications 8 09-08-2007 03:13 PM
does this clear 37's Seeker_jeff Titan Suspension 4 03-18-2007 05:16 PM
cst 8'' on 37's trophytitan666 Titan Pictures & Media Post 24 04-02-2006 01:59 PM
before, after 6in, and after 37's foytiX Titan Suspension 16 11-16-2005 06:31 AM
? for all with 37's and up foytiX Titan Wheels, Tires & Brakes 13 11-10-2005 07:30 PM
