User Name
Password
SAW's on the way - being discussed at Nissan Titan Forums in the Titan Suspension section.
Old 04-29-2008, 10:37 PM   #61
Schrute
Schrute's Avatar
Re: SAW's on the way
Originally Posted by Hawaiianbasshead
sweet! got me a 3" bodylift got piggybacks sitting outside for the back, and hope to order fronts with UCAs soon and a deaver and shackle so I can have it similar to your truck , w/3" bodylift as well... should be able to clear my 36x13.5x17 with an +18 offset by looking at your truck. my 36"s are bald anyway so measure 35"
thanks for the wheel/tire specs. sick truck!
No problem on the specs. Post some pics when you get your suspension goodies installed!
08 LE 4x4 Majestic Blue w/Tow. SAW C/O's (2.5" preload). PRG UCA's. PWM. Swaybar removed. SAW Piggybacks. Deaver C10 leaf pack (largest leaf removed). PRG Shackles (set at -1"). PRG OR Traction Bars. American Racing Motto MT100 20x8.5 chrome wheels. 35x12.50 Toyo M/T's. AEM Brute Force Intake. Nismo Exhaust. 2 Degree Advance. AMP Powersteps. Hella 500 driving lights. ScanGuageII. Debadged.
Schrute is offline   Reply With Quote
Old 04-29-2008, 10:49 PM   #62
Hawaiianbasshead
Hawaiianbasshead's Avatar
I've been here for 4 years so it may still be a while had the truck since 05.... at least I got my rear piggybacks sitting outside ready to install
http://vids.myspace.com/index.cfm?fu...d=19847 42576
Old 04-29-2008, 10:56 PM   #63
CHUD
Is this true? Can you run the bracket lift SAW's without a bracket lift? This is the first I've heard of this... Doesn't seem possible, but if true I wish I would have known about this sooner!!! Need to call Greg.
No, I think DRTYAZN is wrong if that's what he meant. You can't use the SAWs for bracket lifts unless you install the bracket lift components, or you opt for a mid-travel or long travel setup. I believe they're just too long. The longest SAW you could use for your application is the one you have (same as mine)... extended travel SAW.
By the way, nice job on your ride!
CHUD is offline   Reply With Quote
Old 04-30-2008, 12:29 AM   #64
Schrute
Schrute's Avatar
Cool, thanks Chud!
Old 04-30-2008, 05:40 AM   #65
t22a80
t22a80's Avatar
Send a message via AIM to t22a80
I was hoping the same thing but Greg said its not possible. They are just too long! That was my hold up, I wanted the SAW's but I also didnt want to spend the money because I knew I'd want a lift eventually too...
Chad
AKA "Mini Whore™" And now AudioWhore™
MODS: CST 7" lift, PRG UCA, SAW coilovers, SAW rear shocks, Deaver spring pack, PRG blocks, MotoMetal 951's 20x9, Mickey Thompson 35x13.5 Baja ATZ, S&B intake, Flowmaster Delta 50 muffler, Borla tip, 2* timing, projector lights, HID conversion (fog and low beam), Eclipse CD5000, 2x Arc Audio XXK-2500's, CDT speakers HD-M6 mid, braxial mount DRT-26 tweeter, Upstage 500XT, ES-01 tweeters CL-6x (rear fill), HD-10" sub, Tech12volts box, Kicker wiring, Ramatt sound deading, Active Tuning grounding kit. More to come!
t22a80 is offline   Reply With Quote
Old 04-30-2008, 05:53 AM   #66
Blackbeauty
Blackbeauty's Avatar
Just do it, you slacker! Do you see how many "used SAW's" threads are on here? And how many don't sell? NONE! Get off the pot, SLACKER!!!
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
User Name
Password
SAW's are back on Yeti77 Titan Suspension 11 12-20-2007 03:47 PM
SAW's on way back... Yeti77 Titan Suspension 9 11-23-2007 12:27 AM
PC stage 1 and SAW's?? Yeti77 Titan Suspension 12 11-06-2007 07:30 AM
New PRG Custom SAW's Rhino404 Titan Suspension 19 09-25-2007 06:21 PM
Just got Back from PRG with SAW's! Justintoxicated Titan Suspension 32 07-18-2007 08:20 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
