User Name
Password
SAW c/o (silver spring) - being discussed at Nissan Titan Forums in the Titan Suspension section.
Old 04-16-2008, 06:07 AM   #31
hooligan
hooligan's Avatar
Re: SAW c/o (silver spring)
i'm just here to say the silver springs performed flawlessly in the desert! WOOT!!!!
PRGsite <> PRG/ID prerunner fenders
Old 04-16-2008, 06:19 AM   #32
Juday
Juday's Avatar
The red springs would have done better...
285/70/17 BFGoodrich All-Terrain T/A KO
DIY Air Box Mod w/ Drop in AMSOIL EaA Air Filter
TomTom One XL Navigation
2* Timing Advance
Old 04-16-2008, 07:07 AM   #33
hooligan
hooligan's Avatar
LOL Juday!!!
Old 04-16-2008, 08:00 AM   #34
racerjb
Thanks Gofast, that is the exact lift, tires, shocks, wheel combo I want to go with for my 08 Pro4x.
racerjb is offline   Reply With Quote
Old 04-16-2008, 10:41 PM   #35
GoFast33
GoFast33's Avatar
I visited Sway-A-Way in Chatsworth, CA today to get my rear shocks re-filled with nitrogen (I was experimenting with lower pressure...didn't improve anything). Man, those guys are so nice! Also, one of my front c/o's was missing a set screw in the preload collar so they put one in for me. I had Chris under my front fender and Brian under the rear axle at the same time! It felt like I had my own pit crew!!! Thanks again, SAW!!!!!
2008 Pro-4X Crew Cab Long Bed
Pro Comp 6", SAW front (0.75" preload), SAW rear, 18x9 XD Rockstar, 35x12.5x18 BFG KM2
GoFast33 is offline   Reply With Quote
Old 04-16-2008, 11:31 PM   #36
Schrute
Schrute's Avatar
GoFast - Just curious, why were you experimenting with lower pressures? Ride too stiff?
08 LE 4x4 Majestic Blue w/Tow. SAW C/O's (2.5" preload). PRG UCA's. PWM. Swaybar removed. SAW Piggybacks. Deaver C10 leaf pack (largest leaf removed). PRG Shackles (set at -1"). PRG OR Traction Bars. American Racing Motto MT100 20x8.5 chrome wheels. 35x12.50 Toyo M/T's. AEM Brute Force Intake. Nismo Exhaust. 2 Degree Advance. AMP Powersteps. Hella 500 driving lights. ScanGuageII. Debadged.
Schrute is offline   Reply With Quote
Old 04-16-2008, 11:47 PM   #37
GoFast33
GoFast33's Avatar
I've posted this a couple of times in different forums, but my truck hops pretty bad on certain concrete stretches of highway from the expansion joints. I've been suggested that lowering the pressure might be a solution --- nope, didn't help. I talked to Deavers today and they confirmed it is due to the longer wheelbase (an engineer there has the same truck and the same issue). Adding weight to the rear seems to help (rides better with full tank). Oh well, I guess I will learn to live with it, because besides that, it rides like a dream!
Old 04-17-2008, 12:28 AM   #38
Schrute
Schrute's Avatar
Must have missed your other posts - just got back from a little vacation and didn't get on TT much the last week.
That sucks about the hop. I probably missed this too, but what else are you running in the rear besides the piggybacks? Again, just curious.
Old 04-17-2008, 06:49 AM   #39
GoFast33
GoFast33's Avatar
Everything else is stock. Thinking about the deaver pack to replace the block, but it's not available yet for the long bed (longer spring) plus I'm not sure I want it any stiffer. I'm really tempted to get the traction bars from all the rave reviews lately but UCA's are next on my list.
Old 04-17-2008, 09:35 PM   #40
Schrute
Schrute's Avatar
I don't know if they would help with the hop, but the traction bars are great - really makes the rear end feel solid! (That's what she said)
Old 04-18-2008, 07:27 AM   #41
Derwud
Derwud's Avatar
Do you have Big Tow?
'05 4x4 SE, O/R, Big Tow, Rear Video (Kids favorite option). Stillen Grille, AMP Powersteps, SAW's all around, TC UGA's, Modified Deaver Mini Pack, Air Bags, Moto Metal 951's 18x9, BFG A/T 285/65-18's, Air Box Mod and K&N drop in, Gibson Exhaust. Towing WW FS2300 Toyhauler and all the toys.
The Rhino, The Titan, Truck and Trailer
I HIGHLY recommend PRG Products, SDR Motorsports, Desert Works Fabrication, Live Wire Whips, and Gibson Exhaust
Old 04-18-2008, 09:49 PM   #42
GoFast33
GoFast33's Avatar
Yes, why do you ask?
Old 04-19-2008, 05:43 AM   #43
Derwud
Derwud's Avatar
Do you still have the overload spring is the rear? If you do, get the deavers, ditch the overload and the block and I'm sure it will be better.
Old 04-19-2008, 08:21 AM   #44
hooligan
hooligan's Avatar
what he said... overload bar no bueno... unless of course yer towing...
Old 04-19-2008, 08:29 AM   #45
GoFast33
GoFast33's Avatar
I have been considering this, but thought that since the leaf pack would be replacing the block and the stock overload spring to get the same lift (see description from PRG below), it would result in an even stiffer ride. Also, Deavers does not have a spring pack yet for the long bed (longer spring). Hopefully, they will develop one soon.
PRG Deaver Titan C-30 3-Leaf Spring Pack
Description
These 3 leaf add-a-leaf packs are designed to give a bit more lift and a bit more load handling than the C-10 pack, but are otherwise the same. They are added in place of the overload leaf on your stock spring packs. These springs will provide approximately 3.5" of lift on a 4wd and approximately 2.5" of lift on a 2wd. They can be used in place of a block on the ProComp, Rancho, or Fabtech kits.
User Name
Password
Wtb: Overload Spring comeonitsatitan Buy/Sell 1 10-02-2007 08:53 PM
Spring Slap? MuskyHunter Titan Problems & Dealer Service 4 07-26-2006 01:16 PM
New Leaf Spring dckwsu Titan General Discussion 0 07-01-2005 08:52 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
