Old 04-24-2008, 10:20 PM   #1 (permalink)
bigblue35's Avatar
Send a message via AIM to bigblue35
cutting the front coils?
hey guys im gonna be puttin 22s on my truck and i wanna lower it to give it a better stance. would it be ok if i cut the coils 1" to lower the front? im not sure how that works so just wondering what you guys think about it? will it suffer the ride? should i just buy new lowered coils?
07 SE BT 4x4, volant intake, tinted windows and tail lights, flat black wheels. more to come in the next week.
bigblue35 is offline   Reply With Quote
Old 04-24-2008, 10:27 PM   #2 (permalink)
kartman's Avatar
Re: cutting the front coils?
That will work fine but its better to get a torch, heat up the springs real hot and they will compress and when cooled be lower.
Rebar Wrangler
Old 04-25-2008, 08:19 AM   #3 (permalink)
I wouldn't go with either of those... do it right. I'm not sure the options for the front, but get greg's drop shackles for the rear.
I've tried both cutting & heating coils before on previous vehicles and the ride was terrible.
'07 Black SE 2WD "Poser"
Skumbag is offline   Reply With Quote
Old 04-25-2008, 09:02 AM   #4 (permalink)
Pops's Avatar
The ride will be rough. Nissan coils are hard in the center and softer towards the ends and by cutting off an end, you're cutting away the softer part of the spring.
2005 Armada LE 4x4 - 2* Timing Advance - AirBox Mod - PRG Mini-Lift - Nitto TerraGrapplers 325/60-18
_____________
. Check out my Gallery! .
Old 04-25-2008, 09:23 AM   #5 (permalink)
motox214's Avatar
Send a message via MSN to motox214
I agree! I had a friend try and do this and the ride SUCKS! So he is looking for an after market kit! I haven't seen him in awhile so I dont know if he found one!
motox214 is offline   Reply With Quote
Old 04-25-2008, 05:31 PM   #6 (permalink)
bigblue35's Avatar
hey thanks guys, ill just have to be on the look out for 2" drop kit front coils.
i already ordered the shackles from greg, and im gonna pull a leaf in the rear. so i want the front to be alittle lower also. ill see how it turns out.
Old 05-01-2008, 03:14 PM   #7 (permalink)
Chrismatic's Avatar
your best option is to get spindles... when you cut or purcahse new springs it will sit near the bump stop....you sill loose 1" of travel if you go with springs. just my experince...good luck.! any questions just holla!
Chrismatic is offline   Reply With Quote
Old 05-01-2008, 04:55 PM   #8 (permalink)
loufish's Avatar
When you shorten a coil spring, it gets stiffer. I don't remember what the Titans front coil springs look like, so I can't say cutting is even an option...
Those telling you to get a lowering spring are giving you good advise...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Was it worth cutting in front of me? Helinut1970 Off-Topic Discussion 22 12-20-2006 07:16 AM
f/s donahoe front coils**so cal** mytitan Buy/Sell 4 10-06-2006 12:37 PM
Front lift coils Chad Smith Titan Suspension 3 09-10-2006 08:17 AM
Front Lift Coils Lady Nissan 4x4parts.com 5 05-24-2006 08:48 AM
Front Coils pisswilly Buy/Sell 8 04-14-2006 11:24 AM
