User Name
Password
Rear Icons Installed - being discussed at Nissan Titan Forums in the Titan Suspension section.
Old 04-18-2008, 02:39 PM   #1
Jerrygfd
Jerrygfd's Avatar
Finished installation of my rear Icon shocks I received from Greg today. I had to install them with boot down because they were designed that way. I tried to reach Greg to ask him but called Vehicle Dynamics and spoke to Jeremy. He confirmed that the shock designed required installation boot down. Anyway, a very noticeable difference and comfort in the ride especially on dirt roads, a lot smoother. Now I just have to call Greg and confirm the correct SAW's for the front before I order them.
2004 Smoke Color SE 4 X 4 Crewcab fully loaded with Off Road Package, Popular Pkg, Util Pkg, Big Tow Pkg, SplashGuards, Floor Mats,
I installed after purchase: *Dealer installation
Bug Deflector,
Wade Window Vent Visors
Westin Platinum Step Rails
Carriage Bolt Billet Grilles Upper and Lower
Stillen Dual Rear Straight Exhaust Part #509547*
K&N 77 Series Polished Alum Air Mod Kit #6012KP*
Trailmaster Front Coil Spring Leveling Kit #NL220*
Husky rear floor mats
TruxedoTonneau Lo Pro Cover
Prodigy Brake Controller
IPOD Interface Kit
Firestone Ride Rite Air Bags part #2355
Towing on vacations: 2008 Keystone Hideout 28'
Model 27B Travel Trailer with Eaz-Lift 1000/14000 WD and Robins Sway Bar.
DR Rear shocks
Future Mods: Front SAWs coilovers or Bilstein Adjustables
Jerrygfd is offline   Reply With Quote
Old 04-18-2008, 09:02 PM   #2
Hawaiianbasshead
Hawaiianbasshead's Avatar
Re: Rear Icons Installed
I thought I read on here it can be mounted tube down? I was thinking of getting those today over saws just because of that oh well... saws it is then... :looks around go Hooligan to come by and laugh about my change of mind all over again... plus Icons are cheaper and I want shocks sooo bad it's killing me waiting til I can afford saws...
http://vids.myspace.com/index.cfm?fu...d=19847 42576
Old 04-20-2008, 11:09 PM   #3
NorCal 4x4
NorCal 4x4's Avatar
The Bilstein 5125 that Greg sells for slightly less than the ICONs are also great shocks and mount boot up. http://www.prgproducts.com/shop/prod...n_rear_shocks/
Silver '04 Titan SE Crew Cab 4x4 w/E-LOCK® - Born on 05/18/04 in the USA ... 33.5" Toyo M/Ts;
Old 04-20-2008, 11:33 PM   #4
hooligan
hooligan's Avatar
hahaha... busted!!! changing your mind again, ehhh??? lmao... gonna throw a party the day you choose something in the suspension department!
PRGsite <> PRG/ID prerunner fenders
Old 04-21-2008, 07:59 PM   #5
Hawaiianbasshead
cheapness owns me majority of the time idiocracy gets me too
Old 04-21-2008, 08:03 PM   #6
Arachnid
Arachnid's Avatar
$10 difference, and if you read Greg's description he seems to favor the Icon.
AKA: Critter Whore™
Arachnid is offline   Reply With Quote
Old 04-21-2008, 09:04 PM   #7
NorCal 4x4
NorCal 4x4's Avatar
The ICONs are limited to 2" rear lifts, (except a 2wd can go up to 3" if they use the 4x4 version). The Bilstein 5125s are available in several lengths.
Hawaiianbasshead doesn't want boot-down, so these are a good option.
I used to run the Bilsteins and they were great. The DREs, (ICONs), are also nice. I think the 0-3" Bilsteins are firmer.
Old 04-21-2008, 09:55 PM   #8
Hawaiianbasshead
so, how much lift will a 2.5" deaver add on a 4wd?
Old 04-21-2008, 10:01 PM   #9
NorCal 4x4
NorCal 4x4's Avatar
The PRG/Deaver C10 will give 2.5" of lift to a 4x4.
http://www.prgproducts.com/shop/prod...f_spring_pack/
The PRG/Deaver C30 will give 3.5" of lift to a 4x4.
Old 04-21-2008, 10:14 PM   #10
Hawaiianbasshead
yeah, I just gathered that on his site, sounded like 4wd is 1" taller stock from the leafs being different is what I gathered... but I could be wrong...
last question, Greg only sells 2 models of SAW 2.25" rears correct? so the one in the classified would work with a 2.5" deaver spring on my 4wd it looks like I don't mind a rake a little and want shocks
Old 04-21-2008, 10:45 PM   #11
NorCal 4x4
NorCal 4x4's Avatar
Yeah, Greg said something about the spring perch on the 4x4s being located different.
The one in the classified by Gonpostal is the longer one, "2-4" rear lift 4wd". So it should work with both the C10 and the C30 PRG/Deavers on a 4x4.
User Name
Password
Navigon Titan truck 3d vehicle icons gksmith Titan Parts & Accessories 0 12-26-2007 09:01 AM
Just installed new Donahoes on the rear. Titantexan Titan Suspension 7 02-26-2007 08:46 PM
FINALLY! new rear installed rodney Titan Problems & Dealer Service 1 01-14-2007 05:41 AM
Rear Cam Installed Today fdiesel Titan Visual & Audio Discussion 18 04-12-2006 05:52 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
