Old 04-19-2008, 08:46 AM   #1 (permalink)
Question which one do i need
some of the leveling kits say 2'' and 2.5'' for a 4x4. does it matter which one i get?
Down South is offline   Reply With Quote
Old 04-19-2008, 09:59 AM   #2 (permalink)
yamatitan's Avatar
Re: which one do i need
yes get the 2"
Procomp 6" ($1300.00)
35x12.5x18 Toyo MT's $1100.00)
PRG Offroad Traction Bars ($489.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
SAW coilovers ($1000.00)
Bushwacker Pocket style flares ($600.00)
Rear Sway-away piggybacks ($399)
Money wasted so far=$9073.00
Old 04-19-2008, 10:27 AM   #3 (permalink)
Titan1080's Avatar
I had the 2.5" Daystars on for a few months and that truely sucked. Aside from the coil springs being super stiff, any bit of mild off-roading or going over speed bumps too fast would make the upper control arms hit the coil bucket. 2.5" leveling kits are for 2WD only Titans.
AKA, Rusty Whore™
2004 Titan XE KC 4x4 DOB 12-15-2003
Compare your truck to mine and then kill yourselves!
Click Here to see a list of things I did to void my warranty
My Picture Gallery
Titan1080 is offline   Reply With Quote
Old 04-19-2008, 05:54 PM   #4 (permalink)
t22a80's Avatar
Send a message via AIM to t22a80
You can pick between the 1.3" or 2" for a 4x4
http://www.prgproducts.com/shop/prod..._leveling_kit/
PRG makes the best kit because it comes with upgraded bumpstops.
Chad
AKA "Mini Whore™" And now AudioWhore™
MODS: CST 7" lift, PRG UCA, SAW coilovers, SAW rear shocks, Deaver spring pack, PRG blocks, MotoMetal 951's 20x9, Mickey Thompson 35x13.5 Baja ATZ, S&B intake, Flowmaster Delta 50 muffler, Borla tip, 2* timing, projector lights, HID conversion (fog and low beam), Eclipse CD5000, 2x Arc Audio XXK-2500's, CDT speakers HD-M6 mid, braxial mount DRT-26 tweeter, Upstage 500XT, ES-01 tweeters CL-6x (rear fill), HD-10" sub, Tech12volts box, Kicker wiring, Ramatt sound deading, Active Tuning grounding kit. More to come!
Here is my friends Rav4 for comparison. The first pic doesn't do the lift justice!
t22a80 is offline   Reply With Quote
Old 04-20-2008, 10:49 AM   #5 (permalink)
thanks guys
Old 04-20-2008, 10:51 AM   #6 (permalink)
hey t22a80 did you go with the 2''
Old 04-20-2008, 11:22 AM   #7 (permalink)
t22a80's Avatar
Yes I have the 2".
Chad
Old 04-20-2008, 11:25 AM   #8 (permalink)
do you have a pic of your truck i can see, and also whats up with the 3'' that ive seen online
Old 04-20-2008, 11:26 AM   #9 (permalink)
Arachnid's Avatar
Go with the 2" PRG like Chad said, you won't be dissapointed.
AKA: Critter Whore™
Arachnid is offline   Reply With Quote
Old 04-20-2008, 11:35 AM   #10 (permalink)
i know everyone lives and breathes prg on here but, i can get a ncd kit with reward points at work any pros or cons about that kit
Old 04-20-2008, 05:13 PM   #11 (permalink)
t22a80's Avatar
Sure do... she just got a bath today!!
Chad
Old 04-20-2008, 05:18 PM   #12 (permalink)
t22a80's Avatar
Well there are a couple reasons.
1. PRG was the first, NCD looks very similar for some reason.
2. PRG gives you updated bump stops.
3. PRG is a site sponsor and helps keep these boards online.
4. PRG is a great guy and will answer any questions you have.
5. PRG makes the one for your truck. I believe NCD only makes a 2.5.
Is that enough?
I'm not knocking NCD but this is why I support PRG.
Chad
