Old 05-06-2008, 06:19 PM   #1 (permalink)
jcoxtitan's Avatar
Lower Control Arms!!!
Hey I was wondering does anybody know where I could find a set of extended lower control arms, and buy just them without all the other stuff like comes in a fabtech lift?
jcoxtitan is offline   Reply With Quote
Old 05-07-2008, 01:23 AM   #2 (permalink)
kartman's Avatar
Re: Lower Control Arms!!!
I think fabtech still makes ext beams.
What are you going to do with ext lowers and stock uppers?
Rebar Wrangler
Old 05-07-2008, 09:28 AM   #3 (permalink)
jcoxtitan's Avatar
I thought the fabtech lifts came with extended lowers and I want the lowers to coplement the total chaos uppers, I'm not going to use stock uppers but total chaos uppers, coilovers, and spindles, with lower arms for maximum lift and the best ride.
Old 05-07-2008, 10:19 AM   #4 (permalink)
pecora55's Avatar
There are no extended lower control arms out there by any of the lift companies for a titan that I know of, plus you wouldnt need them for what you plan on doing. i do believe, however, that gregs MT kit uses extended lowers but also a different UCA. NCD does as well i guess for their LT kit and apparently camburg does for their LT kit (i assume??)
'07 Nissan Titan SE CC 4x4
pecora55 is offline   Reply With Quote
Old 05-07-2008, 10:57 AM   #5 (permalink)
kartman's Avatar
That would give you a crapload of camber. Bad idea.
Rebar Wrangler
Old 05-07-2008, 12:17 PM   #6 (permalink)
jcoxtitan's Avatar
Then what is camber? I'm not sure what that is. I know its a stupid question but i'm sorry.
Old 05-07-2008, 12:22 PM   #7 (permalink)
54warrior's Avatar
The top of the tire would be leaning waaaay in as compared to the bottom of the tire.
instead of
Old 05-07-2008, 12:24 PM   #8 (permalink)
Juday's Avatar
This is camber:
285/70/17 BFGoodrich All-Terrain T/A KO
AEM Brute Force CAI
TomTom One XL Navigation
2* Timing Advance
PRG Shackles (Still need to install these...)
Old 05-07-2008, 12:47 PM   #9 (permalink)
SDTitan1's Avatar
TC UCAs aren't extended, I think that's where you're confused and think you need extended lowers
SDTitan1 is offline   Reply With Quote
Old 05-07-2008, 12:48 PM   #10 (permalink)
54warrior's Avatar
Originally Posted by Juday
Is it only me that the image won't load for???
Old 05-07-2008, 03:34 PM   #11 (permalink)
hooligan's Avatar
and the rare CST LT kit... don't know if camburg is making the LT kit anymore although i've seen a set at Kartech displayed up above the display cases. well, maybe they still are...
Old 05-07-2008, 03:45 PM   #12 (permalink)
kartman's Avatar
Do yourself a favor and talk with an expert and stop going with your own ideas.
Rebar Wrangler
Old 05-07-2008, 04:54 PM   #13 (permalink)
hooligan's Avatar
yeah, before we see another hack job.......
Old 05-07-2008, 05:03 PM   #14 (permalink)
jcoxtitan's Avatar
ok thanks i just new to the titan and didnt know that the total chaos werent extended i thought they were and that got me mixed up thanks for clearing everything up. I'll just go withh the coilovers, coilover spacer, uca, and spindles in that order. Would it be a problem lifting the truck in that sequence or not?
Old 05-07-2008, 05:10 PM   #15 (permalink)
hooligan's Avatar
call greg at PRGproducts http://www.prgproducts.com/contact-us/
he can set you up accordingly and depending on what your goal is, put your list in the right order.
FS: Stock Lower Control Arms pecora55 Buy/Sell 3 05-15-2008 01:03 PM
Wanted: Lower control arms kaptainswanky Buy/Sell 2 02-25-2008 06:24 PM
WTB Upper & Lower Control Arms. slayer Buy/Sell 3 02-07-2008 09:17 PM
WTB stock upper control arms/lower control arms ghostcustoms Buy/Sell 11 10-15-2007 02:24 PM
Wanted, lower control arms 05se Buy/Sell 4 09-16-2007 04:05 PM
