Old 04-25-2008, 09:44 AM   #1 (permalink)
PRG Extended Travel Package...?
In the next couple months I'm planning on upgrading the suspension to go with my new tires/wheels. I was looking at the "Extended Travel package" that Greg offers. Does anyone have any input on it? What should I expect for my $3k? If I wanted to go deeper into it and go for a MT kit, would it be an easy upgrade later? or would too many parts of the Extended Travel kit be replaced? Trying to be somewhat cost effective here. Try not to laugh, but my inspirations gotta be the late 80's RC Tyco Bandits...
CLICK FOR PIC =)
PIC OF BLACK ONE i used to have<--
Goals:
- Lift enough to fit my disco 20s & 35s --Updated:: Going with 37s
- Still be able to tow
- Be able to launch the truck a few times and overall just articulate better for some high speed desert runs.
'07 Black SE 2WD "Poser"
Skumbag is offline   Reply With Quote
Old 04-25-2008, 06:31 PM   #2 (permalink)
Re: PRG Extended Travel Package...?
Lots of folks here use that exact setup and love it. I have the version for 4WD (no spindles) and it's great. Whether or not you should upgrade to "MT" depends on your intended use. If you spend most of your time on the street, but do some light to moderate off-roading/lauching then my guess is your fine with the Extended Travel setup. If you're more hardcore off-road go "MT".
The MT setup varies in cost. You could get the basic setup and use your extended travel shocks (using your OEM coilbuckets) for under 2 grand (I think). But most guys buy the longer shocks, shock hoops, engine cage, air-bumps, plus whatever I'm forgetting. You'll also need glass fenders. This all adds up. I'm thinking 5 to 6 grand? It really depends on how much "upgrading" you want to do. Oh, and then there's the Trutrac, gears from Hoopers, etc. Anyway, it might be overkill for you...
CHUD is offline   Reply With Quote
Old 04-25-2008, 06:44 PM   #3 (permalink)
Is the MT kit ok even if your rig is your daily driver?(of course i have an alternate transportation if the titan got ****ed up in the desert)
himsa123 is offline   Reply With Quote
Old 04-25-2008, 06:44 PM   #4 (permalink)
loufish's Avatar
But most guys buy the longer shocks, shock hoops, engine cage, air-bumps, plus whatever I'm forgetting. You'll also need glass fenders. This all adds up. I'm thinking 5 to 6 grand? It really depends on how much "upgrading" you want to do. Oh, and then there's the Trutrac, gears from Hoopers, etc..
And so on, and so on...I just never ends!
All that for 20's?...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 04-25-2008, 07:32 PM   #5 (permalink)
t22a80's Avatar
Send a message via AIM to t22a80
HAHA thats funny! I still have one of those Bandits packed away at my parents house. I smashed the front bumper and had to glue it a few times. I loved that thing.
Chad
AKA "Mini Whore™" And now AudioWhore™
MODS: CST 7" lift, PRG UCA, SAW coilovers, SAW rear shocks, Deaver spring pack, PRG blocks, MotoMetal 951's 20x9, Mickey Thompson 35x13.5 Baja ATZ, S&B intake, Flowmaster Delta 50 muffler, Borla tip, 2* timing, projector lights, HID conversion (fog and low beam), Eclipse CD5000, 2x Arc Audio XXK-2500's, CDT speakers HD-M6 mid, braxial mount DRT-26 tweeter, Upstage 500XT, ES-01 tweeters CL-6x (rear fill), HD-10" sub, Tech12volts box, Kicker wiring, Ramatt sound deading, Active Tuning grounding kit. More to come!
Here is my friends Rav4 for comparison. The first pic doesn't do the lift justice!
t22a80 is offline   Reply With Quote
Old 04-26-2008, 12:05 AM   #6 (permalink)
Yes, the MT kit is fine on a daily driver. Greg (PRG) has had a super-duper version of his MT kit on his daily driver/work/experimental Titan for quite some time. I believe most of the guys on this forum who run the MT setup use their trucks as daily drivers with no problems.
Old 04-26-2008, 02:09 AM   #7 (permalink)
Hawaiianbasshead's Avatar
I think it's plenty for what you want, but I've never launched my titan so don't know what all it needs for launching. I think it depends on what kind of air you plan on catching really... 2' high all 4 tires or 6' high or what have you... my rear is gonna consist of alot of what you have except SAW 2.25" Piggyback rears and no block just deaver... and I think it'll handle jumps pretty well... just gotta saw the front SAS would probably be ideal but it'd be more worth while to start with a better platform that already has solid axle...
Old 04-26-2008, 09:11 AM   #8 (permalink)
GrayB83's Avatar
I ordered my set-up last week. SAW's front and rear, prg upper arms, and a 1" rear block. Can't wait til it get's here. My wheels came in yesterday and I want to put them on so bad but want to wait until the suspension comes in.
2006 KC SE 4x4 Galaxy Black Big Tow, Captain's chairs
-XD Hoss 20x9, BFG A/T KO's 305/55-20, PRG Perf. PKG. w/ SAW's, Nismo True-dual exhaust, Truxedo Tonneau, 20% tint, Boston Acoustics SX60, S65RC, GT-50 amp, (2)G1's, Tech12 box.
GrayB83 is offline   Reply With Quote
Old 04-27-2008, 01:14 AM   #9 (permalink)
loufish's Avatar
Man are you going to be happy....I've got the same set-up, except I've got the lift spindles, Truely a fun D/Driver!
Born 9/2004
2002 Honda XR650R
Old 04-27-2008, 12:12 PM   #10 (permalink)
Dirt125's Avatar
I'm running SAW's with total chaos upper arms, stock spindles, and the piggyback saw rears and love it. I took it out on the last Barstow trip and it took every hit perfectly.
Dirt125 is offline   Reply With Quote
Old 05-14-2008, 10:00 AM   #11 (permalink)
Well... I've changed my mind after seeing enough pictures.
Street: Procomp 20s
O/R: XE 17s
37" Toyo M/Ts
FRP Front fenders
Is the extended travel going to give me a decent squatty look or do I need to go a different route? I don't want this thing sky high. Greg's & Kevdizzle's rides finally put me over the top to get the 37s.
Advice?
Old 05-14-2008, 12:09 PM   #12 (permalink)
SDTitan1's Avatar
going to be a tight fit, especially in the rear, with 37s
SDTitan1 is offline   Reply With Quote
Old 05-14-2008, 06:00 PM   #13 (permalink)
Street: Procomp 20s
O/R: XE 17s
37" Toyo M/Ts
FRP Front fenders
Advice?
I might have missed something. When you say O/R: XE 17s do mean you're putting the 37s on the stock XE wheels? Are those wide enough? I saw that you'd be using the ProComp 20s on the street.
Old 05-14-2008, 11:55 PM   #14 (permalink)
NorCal 4x4's Avatar
... Greg's & Kevdizzle's rides finally put me over the top to get the 37s.
Advice?
Don't know about Kdizzle's Titan, but I'm pretty sure Greg's has lower gearing since he has a non-Titan rear axle.
Toyo M/Ts in the 17s and 20s are true 37s, so will raise your overall gearing. Hopefully you at least have the BT gears or can get the custom work like BEECHLY did. The Toyo M/Ts are pigs. Even my 33.5s are 73 pounds, but the 37s are 93 lbs. in the 17", and 94 lbs. in the 20".
Even though hooligan probably thought I was giving him sh!t, last night, about tall tires, especially for a Titan without BT/OR gearing, at least he chose short 37s ... 36s, and they weigh about 25 lbs. a piece less than the Toyo M/T!
So my advice is get 34s, but if you've got to have 37s, at least get the BFG AT KOs.
Old 05-15-2008, 09:43 AM   #15 (permalink)
ptgarcia's Avatar
There are plenty of other 37" A/Ts out there also. You're not limited to just Toyo and BFG.
Pauly
mid travel tutttitan Titan General Discussion 4 06-15-2007 07:58 AM
2008 Extended Cab + Extended Bed Spotted Today Hot_Titan Titan General Discussion 2 05-29-2007 05:32 AM
stock shock travel, extended length and compressed length? Hawaiianbasshead Titan Suspension 2 08-18-2006 02:03 PM
Travel! BNSFMike Titan Suspension 5 09-23-2005 05:13 PM
Are Popular Package and Utility Package Worth it? whistler Titan General Discussion 18 11-01-2004 07:07 AM
