Old 04-16-2008, 02:29 PM   #1 (permalink)
yamatitan's Avatar
PRG traction bars rule!
I finally got them put on today. After receiving them I went to put them on and it turns out two of my friends welders are both broken. So I went to 3 different muffler shops and none of them could weld only braze. They all recommend i go to a body shop. So i went to a good friend of my girlfriends dad, he owns a body shop. So i get to talking to him and he wont weld them on because of concern with it weakening the frame, and he did not want to be reliable if something happened. So i went to another that worked on my old truck and they told me the same thing. Finally i went to a local welding shop and they told me the same as well.
So off to my local 4x4 shop where i should have went in the first place. I just did not want to go because i knew they charge 70 dollars an hour labor. Plus they were already mad that i refused to pay them 800 bucks to put on my procomp lift and just did it myself. Anyway they did it no questions asked and about 20 minutes later and 70 bucks poorer i got them welded on.
I love them so far, no more squatting when you take off. The whole rear end feels solid. When punching from a dead stop she just takes off like a rocket. Plus the best part of all not more annoying axle wrap. I used to get a annoying jerk when taking off, even slowly. Thats completely gone now. They even feel solid when braking, i dont know how to explain it but when hitting the brakes real hard i feel more planted on the ground. I have even had a chance to try them offroad yet. So far they have been an awesome investment. I was kinda unsure about spending that much money on a bar but they work great and were defiantly worth it.
Now that the books over here are some pics:
If anyone is thinking about buying these, quit thinking and just do it!
Procomp 6" ($1300.00)
35x12.5x18 Toyo MT's $1100.00)
PRG Offroad Traction Bars ($489.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
SAW coilovers ($1000.00)
Bushwacker Pocket style flares ($600.00)
Rear Sway-away piggybacks ($399)
Money wasted so far=$9073.00
Old 04-16-2008, 02:35 PM   #2 (permalink)
rtc1184's Avatar
Send a message via AIM to rtc1184 Send a message via Yahoo to rtc1184
Re: PRG traction bars rule!
How Much Were They To Your Door?
"PIT CREW"
mods wanted:
stillen supercharger
uprev ecu flash
125 shot of nx
big brake upgrade
steel braided brake lines
master cylinder stiffner
REMOTE START
RHINO LINER
TRU-TRAC
MODS DONE!
8000k HID CONVERSION LIGHTS, REMOVED ALL THE DECALS,TINT, CAI, straight pipe exhaust, AMERICAN RACING VICTOR TEFLON 17X8, 6" BASIC FABTECH LIFT, STACKED LEVELING KIT, 38.5x14.50x17 PRO-COMP XTREME AT'S, 3" BODY LIFT, HITCH, KENWOOD IN DASH DVD 7" MP3/WMA/CD/, 1 15" KICKER SOLO BARIC L7, CRUNCH 1500.1 AMP, THROTTLE BODY SPACER, PAINTED INDIGO BLUE INTAKE COVER,BURNOUT MOD,LED 3RD BRAKE LIGHT, BLUE LED'S UNDER DASH, WHITE FACE GAUGES, BLUE LED DOME LIGHT, TB COOLANT BYPASS, AXLE VENT MOD,
www.myspace.com/stuntin4alivin
rtc1184 is offline   Reply With Quote
Old 04-16-2008, 02:37 PM   #3 (permalink)
yamatitan's Avatar
489 for those, the street bars do the same thing and cost a little less. the only difference is that they are a single tube.
Old 04-16-2008, 02:40 PM   #4 (permalink)
rtc1184's Avatar
Wondering How Hard It Would Be To Make Some Out Of Tubing. I Have A Bad *** Welder At My Dads.
"PIT CREW"
mods wanted:
uprev ecu flash
125 shot of nx
big brake upgrade
REMOTE START
RHINO LINER
TRU-TRAC
MODS DONE!
Old 04-16-2008, 03:07 PM   #5 (permalink)
TitanBlue's Avatar
Welding is easy, getting the Metal cut is the harder part. And knowing the right dimensions, angles, Rod Ends,, Powdercoating the brackets, Precision Drilling the Mounts, Proper Grade Hardware etc...Why do it?
I have the Street Bars, and absolutely love them. I have a welder and torch and whatever, been welding 30 years. I'd buy the PRG anyday! Great Guy (Greg), Great Product.
DYNO: 308 RWHP & 380 RWTQ
~CRANK: 360 HP & 450 TQ
Born June 12, 2006
Adopted June 27, 2006
Old 04-16-2008, 03:16 PM   #6 (permalink)
rtc1184's Avatar
Well That Solves That Then. Ill Buy Them Vs Make Them
"PIT CREW"
mods wanted:
uprev ecu flash
125 shot of nx
big brake upgrade
REMOTE START
RHINO LINER
TRU-TRAC
MODS DONE!
Old 04-16-2008, 03:20 PM   #7 (permalink)
yamatitan's Avatar
I agree its more than just a bar welded to the frame. It would take a little math to get it ride. Plus a bunch of stress is getting put on it, all the trucks tourque so you better have some beefy materials.
Old 04-16-2008, 03:45 PM   #8 (permalink)
DRTYAZN's Avatar
Nicely said... I love mine too... in fact after tearing two transmission mounts in two years, I finally decided to order the PRG street traction bars, along with front/rear SAW's and Deaver leafs... I too experienced the "why in the H3LL did I wait so long to do this???" after installation was completed... so I second the, "if you are thinking about it... stop thinking about it, DO IT!, you won't regret it...
Radiant Silver '06 Titan SE CC 4X4 w/BT&OR w/ ATS Fender Flares
PC 6" lift w/ PRG A arms & traction bars, SAW's front/rear combo & Deaver pack
34" Nitto Terra Grappler's on 17" Helo Maxx 6's
Volant CAI, PowerAid TBS, Flowmaster 40
DECEPTICON center grill, SS Hood Deflector & Chrome Truck Nutz
DRTYAZN is offline   Reply With Quote
Old 04-16-2008, 08:27 PM   #9 (permalink)
Hawaiianbasshead's Avatar
how do you know if your tranny mounts are broken? I think mine are, sometimes when I gas it (which I don't do often for fear it'll happen) it has a delay and a clunk kinda hard one. is that the tranny bouncing under there? my shocks are probably terrible shape now also so probably get worse axle wrap when they're blown I'd imagine... I think I need track bars and saws front and back and possibly new tranny mount
Old 04-16-2008, 11:12 PM   #10 (permalink)
Send a message via AIM to MIZZARK
they look great and the best thing about it, is that its very functional.. cant wait to get mine.. maybe in a year =/
///SIG IMAGE TOO LARGE. PLEASE RESIZE TO 300X200 PX OR LESS\\\
Phaze*2 Mizzark
2007 Titan SE CC Blizzard White
Inside:Pioneer Avic D3
12" kicker punch sub
Performance:Volant CAI Flowmaster Super 40
Outside: LOTS OF STICKERS!!
N-Fab Steps
8k Hid's Headlights
Swapped in Big Tow Mirrors and added oem fog lights.
Rims & tires:Pro Comp Extreme 17x9 wrapped in 35x12.50x17 Cooper STT's
Suspension:
Lifted with 2.5" ncd level spacer and cst 4" spindle lift and pro comp 4" rear blocks & Sway-a-way rear shocks thanks to greg @ prg & jeff @ performance lifts.com
soon to come: SAW coilovers, 2.5 deaver pack, & traction bars
PRG PRODUCTS
PERFORMANCE LIFTS
MIZZARK is offline   Reply With Quote
Old 04-17-2008, 05:06 AM   #11 (permalink)
Demondw3's Avatar
I purchased mine off another member and sat on them for months before I had greg install them. It feels so much better that before from a dead stop take off.
check out my trucks transformation.
http://www.kodakgallery.com/Slidesho...Uy=8mexzr&Ux=0
Demondw3 is offline   Reply With Quote
Old 04-17-2008, 05:07 AM   #12 (permalink)
Blackbeauty's Avatar
I have to agree.. MUCH more solid on takeoffs, turning, stopping... everything! It corners better, and the steering response became a bit more linear. I really like what the traction bars did for this truck! Nice job!!!!
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 04-17-2008, 09:18 AM   #13 (permalink)
has anyone installed them on a stock suspension truck (no lift)? I won't ever lift my truck, but if the benefits are still there with the bars, I may get them.
Seranin is offline   Reply With Quote
Old 04-17-2008, 09:25 AM   #14 (permalink)
The lift doesn't matter. The axle wrap is there on ALL Titans.... These will improve it no matter what you're running. The only "lift" I have is a rear spacer block... not much as far as lifts go. Well worth it IMO....
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 04-17-2008, 09:27 AM   #15 (permalink)
SDTitan1's Avatar
I'm in the same boat you were in D, just have mine sitting here, haven't put 'em on yet.........looks like i gotta do so soon though, lol
"Wait a minute. What did you just say? You're predicting $4-a-gallon gas? ... That's interesting. I hadn't heard that." --George W. Bush, Feb. 28, 2008
SDTitan1 is offline   Reply With Quote
PRG traction bars titanstan Titan Suspension 2 03-12-2008 05:50 PM
Anyone using PRG Traction Bars? MuskyHunter Titan Parts & Accessories 8 01-29-200
