Old 05-10-2008, 07:33 AM   #1 (permalink)
dkeenum2's Avatar
Rough Country Leveling Kit???
Any One Know Anything About The Rough Country Leveling Kit? It Says 3 Inches With A Block In The Back. Good Or Bad?
dkeenum2 is offline   Reply With Quote
Old 05-10-2008, 08:49 PM   #2 (permalink)
Re: Rough Country Leveling Kit???
Short story = Bad. 3 inches is too high for a leveling kit/spacer... control arm will hit the coil bucket. I know PRG makes kits for 2WD and 4WD Titans (different thicknesses) as that their stock heights are different. His kits won't cause problems. You can get up to 2 inches with a spacer. If you want to go higher and you're 2WD you could get the CST spindles (4 inches front). If you want to go plush add some aftermarket coilovers. If you're 4WD, you could get Greg's Extended Travel Package (what I have). Aftermarket SAW coilovers, UCA's, Deavers, shackles, et cetera. It gives you about 3 inches of lift and the ride is a hundred times better than stock.
CHUD is offline   Reply With Quote
Old 05-12-2008, 04:06 PM   #3 (permalink)
dkeenum2's Avatar
awesome thanks bud. i think im just gonna save up and wait for the suspension lift
FS Rough country leveling kit Brand new 06titancrewse Buy/Sell 3 03-03-2008 05:19 PM
2.5" Rough Country leveling kit. Dubbeditup Buy/Sell 13 03-02-2008 08:37 PM
rough country 3 inch leveling kit TITANS04 Titan Suspension 1 01-14-2008 06:17 AM
Rough Country leveling kit hitting control arm. scopemaster911 Titan Suspension 2 04-17-2007 09:43 AM
Rear Blocks with Rough Country??? MXTitan Titan Suspension 6 08-10-2004 06:59 AM
