Old 05-11-2008, 12:42 PM   #1 (permalink)
mr.cash's Avatar
Exclamation prg leveling kit
hey guys i put on my prg leveling kit last night and i have rubbing on what looks like the sway bar ? im not sure what it exactly is but if anyone has had this please tell me what to do it is my inside front on both sides thanks alot
mr.cash is offline   Reply With Quote
Old 05-11-2008, 12:43 PM   #2 (permalink)
Kronos1965's Avatar
Question Re: prg leveling kit
How is that possible?
The leveling kit fits on the tower.
Can you show pictures?
Kronos1965 is offline   Reply With Quote
Old 05-11-2008, 12:48 PM   #3 (permalink)
Blackbeauty's Avatar
Are you sure you didn't put the sway bar endlinks back in the wrong way? It's possible to turn them over when reattaching. Post up some pics and we'll see what's up.
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 05-11-2008, 01:05 PM   #4 (permalink)
mr.cash's Avatar
this is the passenger side
Old 05-11-2008, 01:21 PM   #5 (permalink)
Doesn't look like it's connected right.....
Here's what it should look like:
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 05-11-2008, 01:22 PM   #6 (permalink)
Yellomantis's Avatar
Your end links need to be strait up and down, not horizontal like they are now. Did you disconnect the sway bar when you did the install?
www.myspace.com/yellomantis
Old 05-11-2008, 01:25 PM   #7 (permalink)
mr.cash's Avatar
no it wasnt dissconnected how should i fix it?
Old 05-11-2008, 02:20 PM   #8 (permalink)
mr.cash's Avatar
can anyone help me on how to get this how the above pics is supposed to look ? thanks
Old 05-11-2008, 09:42 PM   #9 (permalink)
You will have to disconnect the end links and flip your sway bar back up. Be careful though. They might have some preload on them. You *may* have to take your coilovers out to do it safely. They probably ended up that way during the install.
Old 05-12-2008, 02:26 PM   #10 (permalink)
mr.cash's Avatar
i jacked up the truck took off the skid plate then unbolted the u clamps and with a friend put it up and down and then put it together worked great thanks again
Old 07-02-2008, 10:32 AM   #11 (permalink)
Titster's Avatar
Sway bar turned over after hitting bump.
It is probably too late for this, but I also had the same problem when I had my shocks changed, I just pushed the sway bar back while the truck was lifted and it fixed it. Unfortunately the end links are now bent. I went over a bump real fast and the sway bar flipped down again. I am going to replace the damn end links and hopefully this won't happen again. I thought I was the only one who had this problem. I guess in some way I am kind of happy to see I'm not the only one. It's an easy fix anyway, I'm glad you got it fixed.
Titster is offline   Reply With Quote
PLEASE Help PRG leveling kit!! Tightan750 Titan Suspension 20 05-11-2007 07:12 AM
2.5” vs. 2” leveling kit for 4x4 TitanDaddy Titan Suspension 4 05-18-2006 05:42 AM
Leveling Kit JackedupBlack Prerunners.com - Titan Leveling Kits 1 04-29-2006 03:32 AM
WTB: Leveling kit? spoonman Buy/Sell 0 04-26-2006 09:37 PM
Any One Experince Procomp Leveling Kit? ---how Hard Is It To Install A Leveling Kit? d0va Titan Suspension 2 03-23-2006 07:16 PM
