User Name
Password
Click Here
Post lift kit removal problems. - being discussed at Nissan Titan Forums in the Titan Suspension section.
Old 05-11-2008, 09:16 PM   #1
my06titan
Exclamation Post lift kit removal problems. HELP!!!!
So after I removed all of my lift kit parts (4"spindles, SAW front coils, SAW rear shocks, 4"blocks) I started to feel heavy vibration (shaking) in the lower RPM. This vibration is very noticeable especially with a heavy load. Now, I haven't removed my CST drop carrier bearing bracket since the removal of my lift kit (since Gregg@ prg told me that I didn't have to...)... and was wondering if the cause of this "vibration" in the lower RPM is because of this drop carrier bearing.
Anyone with knowledge please help me with this. This noticeable vibration is starting to get on my nerves. Also, what do I have to do to fix this vibration if its in fact that this vibration is due to my drop carrier bearing bracket.
Thanks guys.
my06titan is offline   Reply With Quote
Old 05-12-2008, 11:15 AM   #2
my06titan
Re: Post lift kit removal problems.
bump. Any help would sure be appreciated.
thanks
Old 05-12-2008, 12:08 PM   #3
jasonmotox
jasonmotox's Avatar
Seeing as how you don't have your truck lifted anymore....it makes sense to remove the drop carrier bearing IMO. Not to doubt Greg but thats my best guess.
[IMG][/IMG]
07' Osceola Swamp Runner
jasonmotox is offline   Reply With Quote
Old 05-12-2008, 01:06 PM   #4
CVTITAN
CVTITAN's Avatar
Remove the carrier drop and the vibe is gone. Now your pinion angle is off..
BIG WHITE TRUCK...
CVTITAN is offline   Reply With Quote
Old 05-12-2008, 01:21 PM   #5
jasonmotox
jasonmotox's Avatar
why would his pinion angle be off now that he's removed the lift?
hey, how much for the front and back SAW's???
Old 05-12-2008, 02:05 PM   #6
my06titan
Thanks for the response guys. What do I replace the CST carrier bearing bracket with? Also, i remembered when Greg installed the CST carrier bearing bracket, he cut a piece of the truck cross member piece.
Thanks again for all of your help.
Old 05-12-2008, 06:06 PM   #7
Peytons_Titan08
Peytons_Titan08's Avatar
sorry jason, i got it all!
2008 Titan XE
K&N CAI
PRG Mini Lift (Coming Soon: Sway-A-Way Coil's, Sway-A-Way Piggy Backs, 4" Spindle Lift, 4" Rear Block)
6000k HID's
08 SE Rims (Coming Soon: 18" Black XD Monsters wrapped in Terra's 325/65/18)
"If you want something you never had, you must do something you have never done"
Peytons_Titan08 is offline   Reply With Quote
Old 05-12-2008, 06:58 PM   #8
JLG
JLG's Avatar
Go to a hardware store and get a piece of 1/4" steel plate to use in place of the carrier bearing bracket. Cut steel plate to length of the bracket drilling two holes using bracket as a template. Remove bracket and install steel plate.
JLG is offline   Reply With Quote
Old 05-14-2008, 12:17 PM   #9
jasonmotox
jasonmotox's Avatar
youuuu greedy bastard!
User Name
Password
Post pics of your lift? GrayB83 Titan Suspension 33 05-08-2008 07:34 AM
post pics, spindle & coil spacer lift. gbgonzal138 Titan Suspension 5 04-27-2008 08:42 PM
removal CST lift ?? beeboyee Titan Suspension 8 06-10-2007 06:24 PM
PRG Minii Lift Post-install Question: HELP!! shaffer Titan Suspension 29 04-18-2007 03:43 PM
post prices of your 4" rancho lift with installation bigpapisj09 Titan General Discussion 0 02-23-2007 08:43 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
