Old 05-12-2008, 07:25 PM   #1 (permalink)
Send a message via AIM to norstartitan
Leveling Kit Issue
Tons Of Great Info On Leveling Kits Here But I Can't Seem To Find What I Need To Know. I Just Had A 2" Ncd Kit Installed. My Question Is This Why Did A 2" Kit Almost Raise The Front 3", The Spacers Were Just Over An Inch Thick. One Side Of The Truck Measures 38 3/4" And The Drivers Side Is 38 1/2" High From The Ground To The Fender; Measured On My Garage Floor. Before The Spacer The Same Measurement Was 36". 2" Was The Max I Wanted As I Just Wanted To Fix The Saggy Nose Issue...
Your Insight Would Be Fantastic.
2006 CC SE 4X4 Silver
2008 GTI 155
2008 RXP-X
2008 Can AM 650 ATV
norstartitan is offline   Reply With Quote
Old 05-12-2008, 07:31 PM   #2 (permalink)
Carbeaux's Avatar
Re: Leveling Kit Issue
It shouldn't have raised you by that much. Was that all you changed? The addition of the spacers?
Hook 'Em Horns!
- Frank Zappa
Old 05-12-2008, 07:34 PM   #3 (permalink)
spoonman's Avatar
Send a message via AIM to spoonman Send a message via Yahoo to spoonman
Drive it around for a bit. When i installed mine it looked higher than i expected in the beginning. After i drove on it it settled down a bit and now it is level.
04 King Cab LE 4x2
Dueler Revo At's, 17" MB Razor's, AEM Brute Force CAI , Billet Grille, NCD 2.5 inch leveling kit (not pictured)
spoonman is offline   Reply With Quote
Old 05-12-2008, 07:44 PM   #4 (permalink)
i just had it done about 5 hours ago and I've put about 10 miles on it since. the spacers were the only thing done to the truck. The truck finally looks like a 4x4; as long as it settles to the 2" rise I thought I was getting it'll be 100%
2008 GTI 155
2008 RXP-X
2008 Can AM 650 ATV
Old 05-12-2008, 08:01 PM   #5 (permalink)
Peytons_Titan08's Avatar
i had the same issue, once i got an alignment it measured correctly.
2008 Titan XE KC
Exterior:
DeBadged
6000k HID
Performance:
K&N CAI
Audio:
Alpine IDA-X001
JL 300/4 Powering - 4 Polk Audio 6.5"
JL 500/1 Powering - 1 JL 10W3v3
Suspension/Wheels:
Total Chaos Upper Control Arms
4" CST Spindle Lift w/4" Rear Block
Sway-A-Way Coilover's (1" preload)
Sway-A-Way 2.25" Rear's
18" Black/Red Ballistic Offroad Jesters wrapped in 325/65 Terra Grapplers.
"LIFE IS GOOD"
Peytons_Titan08 is online now   Reply With Quote
Old 05-12-2008, 08:52 PM   #6 (permalink)
Mighty Titan's Avatar
Originally Posted by Peytons_Titan08
i had the same issue, once i got an alignment it measures it correctly.
x2 same here
Big GunZ
05' Crew Cab 4x4 SE, Off road , Big tow, Big Balls
PRG Mini Lift
Hypertech Max Energy Tuner
Toyo A/T's
Rhino Dominator 2 nerf bars
Wish List:
Tonnoeu cover
CAI and Exhaust
Mighty Titan is offline   Reply With Quote
Old 05-12-2008, 09:05 PM   #7 (permalink)
bleasdell's Avatar
Question Re: Leveling Kit Issue
Guys, just to be clear, is this the type of kit you had installed?:
http://cgi.ebay.com/ebaymotors/2004-...m170218591808&
Is this something that someone who has moderate mechanical skills can do themselves, or will this need the likes of spring compressors, etc.?
bleasdell is offline   Reply With Quote
Old 05-12-2008, 09:16 PM   #8 (permalink)
pretty easy install, just need the right tools. not recommended for 08's or 4x4's. just use a 2".
2008 Titan XE KC
Exterior:
DeBadged
6000k HID
Performance:
K&N CAI
Audio:
Alpine IDA-X001
Suspension/Wheels:
"LIFE IS GOOD"
Old 05-12-2008, 09:32 PM   #9 (permalink)
spoonman's Avatar
2008 come a bit higher from the factory. For 08's it seems the only option is PRG. I believe you ive seen people with 08's put on the 1.3 inch kit. Give him a ring and he should answer your questions.
04 King Cab LE 4x2
Old 05-13-2008, 06:44 AM   #10 (permalink)
bleasdell's Avatar
OK, so you are saying that for my '08 SE a 1.3" kit will be the best. I have searched but cannot find such a kit. Can you please point me in the right direction? Thanks!
Old 05-13-2008, 06:51 AM   #11 (permalink)
Blackbeauty's Avatar
http://www.prgproducts.com/shop/prod..._leveling_kit/
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 05-13-2008, 07:52 AM   #12 (permalink)
i got the ncd 2.5 kit on my cc 4x4 which is the 1.5 spacer looks great and have had no probs highly recommended. they also have the smaller one
Down South is offline   Reply With Quote
Old 05-13-2008, 07:56 AM   #13 (permalink)
bleasdell's Avatar
Originally Posted by Blackbeauty
My fingers must be broken. I don't know how I did not find that. Thanks for the pointer!
Old 05-13-2008, 07:25 PM   #14 (permalink)
hey bleasdell thanks for high jacking my thread.....
Now back to the issue at hand, the alignment sounds like a good idea but the truck tracks as straight as an arrow, i can let go of the wheel and go close to half a mile before i have to make a minor adjustment. measured it again today, same, driver side 38.5" and passenger side 38.75". a two inch lift would have put this at 38" as the center of the fender was 36" from the ground when i started. I'm pretty handy with most things but the suspension issue and alignment thing I'm just not tracking with. I still don't get why a spacer just over an inch thick could lift a truck over 2"s. I'll look into the alignment tomorrow; anything else that may cause the different measurements???
2008 GTI 155
2008 RXP-X
2008 Can AM 650 ATV
Old 05-13-2008, 07:43 PM   #15 (permalink)
bthelton's Avatar
So is it the 0.25" differance from the driver to passenger side bothering you, or the overall height? Reason being sometimes vehicles set a little dirrerent from one side to the other, Take for instance Chevrolets when you order lowering springs DJM would send a 1" bushing for the driverside and not one for passenger so it would set level.
bthelton is offline   Reply With Quote
4x4 issue dksfowler Titan Problems & Dealer Service 5 03-05-2008 06:15 PM
Another Issue Harley Edition Titan Titan General Discussion 13 10-17-2006 07:27 AM
Any One Experince Procomp Leveling Kit? ---how Hard Is It To Install A Leveling Kit? d0va Titan Suspension 2 03-23-2006 07:16 PM
Is this a Horn Issue (First issue for a newbie) lsutyger Titan Problems & Dealer Service 14 10-04-2004 05:39 AM
Another QC Issue? j_farkas Titan General Discussion 6 07-24-2004 06:11 PM
