Re: looking for small lift
you can go two routes to get the 2" you're looking for....
#1 (cheaper route, sacrifices performance as compared to #2)...prg mini lift, gives you 2.5" in the front and 1" in the rear (this kit is top notch and lifts the truck by using a spacer in the front and a block in the rear)
#2 (i would definitely go this route if you can swing the cost, it will give you far improved handling over stock)...radflo adjustable 2.0 coilovers from prg, these will allow you to adjust between 1-4" of lift in the front (they take the place of a leveling spacer and actually give you some more wheel travel, the spacer won't do that) deaver 2.5" mini pack in the rear...these will take the place of your overload leaf and give you about 2.5" of lift in the rear...these will also improve the ride and give you the desired lift you're looking for (if you get these, you'll want to get atleast the icon rear replacement shocks or bilstein 5150s, or, again, if you can swing the cost, you can go with the sway a way piggybacks (these are a great shock, you won't be disappointed with them)....
but, like others have said, you can call greg and he'll set you up with exactly what you need, but i'm thinking he'll probably recommend something like #2 if you want the lift and don't want to sacrifice and ride quality...good luck with your search
cst/// radflo/// sway-a-way/// hankook/// deaver/// pioneer/// t-rex/// deathreat
...only the best for my truck...
