Old 05-21-2008, 11:04 AM   #1 (permalink)
06_SMOKE_SE_CC's Avatar
Check it out!!!
almost done with the truck (yeah right)....
just picked up bechlyf's old kook's 35/12.50/18, here's a comparison shot between the truck with the spindles/radflos in front 2.25 saw piggybacks/2.5" deavers in the rear with my old nitto terra grappler 285/60/18 vs. the same suspension set up with the hankook 35/12.50/18
terra grapplers:
hankooks:
here's a couple more pics of the truck after the tire transformation:
i'll post a couple more later, imageshack is being retarded right now....
cst///radflo///sway-a-way///hankook///deaver///pioneer///t-rex///deathreat
...only the best for my truck...
06_SMOKE_SE_CC is offline   Reply With Quote
Old 05-21-2008, 11:07 AM   #2 (permalink)
walleeme's Avatar
Re: Check it out!!!
Very nice.....
My has almost nothing compared to some of you guys, but I still like it.
MADE IN USA is the way things are supposed to be.
ACCEPT NO SUBSTITUTES.
And if you have to, you have to.
Wallee AKA BaldWhore™
walleeme is offline   Reply With Quote
Old 05-21-2008, 11:10 AM   #3 (permalink)
Re: Check it out!!!
thank you sir....i can't believe i had those tiny little terra grapplers on there before....theyr'e soooooo small....wtf?!!?!?!??!?!
Old 05-21-2008, 11:57 AM   #4 (permalink)
t22a80's Avatar
Send a message via AIM to t22a80
Re: Check it out!!!
Looks good... my uncle has those tires on his Dodge... they are real meaty looking..
Chad
AKA "Mini Whore™" And now AudioWhore™
MODS: CST 7" lift, PRG UCA, SAW coilovers, SAW rear shocks, Deaver spring pack, PRG blocks, MotoMetal 951's 20x9, Mickey Thompson 35x13.5 Baja ATZ, S&B intake, Flowmaster Delta 50 muffler, Borla tip, 2* timing, projector lights, HID conversion (fog and low beam), Eclipse CD5000, 2x Arc Audio XXK-2500's, CDT speakers HD-M6 mid, braxial mount DRT-26 tweeter, Upstage 500XT, ES-01 tweeters CL-6x (rear fill), HD-10" sub, Tech12volts box, Kicker wiring, Ramatt sound deading, Active Tuning grounding kit. More to come!
t22a80 is online now   Reply With Quote
Old 05-21-2008, 12:14 PM   #5 (permalink)
CBURNS1101's Avatar
Re: Check it out!!!
trucks coming along good!!!!!!!!!!
CBURNS1101 is offline   Reply With Quote
Old 05-21-2008, 05:20 PM   #6 (permalink)
MXtitan24's Avatar
Re: Check it out!!!
sick as hell
cant wait to see what comes next
>2004 SE Charcoal/Smoke/Gray CC
-FLowmaster 40 Series
-Two 12" Rockford Fosgate Punches
-Crossfire Amp
-Self Built Fiberglass Box
-Clarion In-Dash TV
-Debaged
-5% Tint so you can't see up in my windows
-RaceRunner Coilover
-CST Spindle (7.5 up front)
-Bilsteins & a Block in the Rear (3 in the back)
-Dual PRG Stickers
>CRF 450
>CRF 250
>2004 Nissan Frontier 4x4
>1960 Rag Top Bug
>1959 Euro Rag Top Bug
>1967 VW Baja Bug
MXtitan24 is offline   Reply With Quote
Old 05-22-2008, 05:12 AM   #7 (permalink)
Re: Check it out!!!
not sure what's next, there's three or four things that i want to do, but don't know which one to get....any input?
tru trac
frp fenders
prg offroad traction bars
go rhino dominator II's
i have no idea....
Old 05-22-2008, 05:25 AM   #8 (permalink)
MADAPAKA's Avatar
Send a message via AIM to MADAPAKA
Re: Check it out!!!
Nice!!! What a difference!
MADAPAKA is offline   Reply With Quote
Old 05-22-2008, 05:28 AM   #9 (permalink)
Re: Check it out!!!
thanks....i knew those nittos were too small, but i just didn't realize how small until i saw the hankooks on there...the kooks have been nice so far, they're not loud at all, especially for mud tires....
only negative is that i've seen the mpg drop considerably....went from 15-16 down to about 13 ....but, i guess you gotta pay to play right??
Old 05-22-2008, 05:50 AM   #10 (permalink)
BK19702's Avatar
Re: Check it out!!!
Those Kookies look awesome on the truck!
2006 XE KC 4x4, Galaxy Black
Preferred Package, OEM Bug Deflector
Sirius Satellite Radio / IPOD (Plug in kits)
AMSoil 5W-30XL Synth. Motor Oil, OEM Oil Filter
AMSoil Drop in dry air filter/Air Box Mod
AMSoil 75W-140 Severe Gear Rear Diff Fluid
Mobil 1 75W-90 Synthetic Front Diff Fluid
Toyo Open Country AT's P265/70/17
BK19702 is offline   Reply With Quote
Old 05-22-2008, 08:34 AM   #11 (permalink)
MXtitan24's Avatar
Re: Check it out!!!
tru trac
frp fenders
i have no idea....
do them all
-Crossfire Amp
-Clarion In-Dash TV
-Debaged
-Dual PRG Stickers
>CRF 450
>CRF 250
>1960 Rag Top Bug
>1967 VW Baja Bug
Old 05-22-2008, 08:55 AM   #12 (permalink)
BECHLYF's Avatar
Re: Check it out!!!
For every single rotation of the 35's your truck moves a further distance. so if the speedo reads 75 mph you might be around 80 mph, your speedometer will be off and so will your tripometer they will read less. if the tripometer says you went 260 miles on that tank you have actually gone more. the odometer will read less too
Old 05-23-2008, 11:52 AM   #13 (permalink)
Re: Check it out!!!
sweet, then i'm actually getting better than 12 mpg....
just tried them out in some mud this morning on the way home from work....FLAWLESS PERFORMANCE....thanks again for the great deal bech!!!
Old 05-23-2008, 11:52 AM   #14 (permalink)
Re: Check it out!!!
Originally Posted by MXtitan24
do them all
if only that were an option sir...
Old 05-24-2008, 06:07 AM   #15 (permalink)
hooligan's Avatar
Re: Check it out!!!
....but don't know which one to get....any input?
frp fenders
i have no idea....
frp fenders, paint the wheels black, order/install black door handles, prg shackles dropping the rear 1/2"... you're good to go!
PRGsite <> PRG/ID prerunner fenders
Check Out The 24s! JAS522 Titan Wheels, Tires & Brakes 14 08-29-2007 05:30 AM
check this... has anyone done this? hobbsy Off-Topic Discussion 6 08-16-2007 09:33 PM
check this out! Yellomantis Off-Topic Discussion 5 08-18-2006 01:47 PM
check this out! PrerunnerGreg Titan General Discussion 20 06-13-2005 09:48 AM
Check Your Aim Stitch Titan General Discussion 5 11-27-2004 04:54 PM
