Old 05-24-2008, 09:41 PM   #1 (permalink)
North Country Titan's Avatar
Beating the dead horse levelling kit issue again
I know there are dozens of posts about these levelling kits out there, but i'm lost. So straight up ;i have the ncd 2.5 kit on and it makes one hell of a bang when i go over hard bumps like parking lot speedbumps. I'm talking teeth shattering , looking around to see if i've lost any parts bang.I don't recall it doing this before the kit. The noise is happening not on the compression but on the rebound of the shock.
i made sure to ask at the dealership when i had it put on if there was going to be any warranty issues and they said probably not.
I've read it's the strut , the arm , loose nuts etc.. what is the bottom line on these ? Is it the kit thats causing this or bad factory parts? Did anyone elses truck do this before the kit or only after?I want to go to the dealer and give them a heads up on this(there pretty reasonable when it comes to listening to problems !)If it's factory are they covered by the warrantry?
So please somebody give me a straight up answer !
North Country Titan is offline   Reply With Quote
Old 05-24-2008, 09:56 PM   #2 (permalink)
scottsbro23's Avatar
Re: Beating the dead horse levelling kit issue again
If you have a 4x4 and installed a 2.5" spacer, then it could be what you are feeling and hearing is the Upper control arm hitting the coil bucket as the suspension moves toward full droop.
Happiness Is Beating Bama in Anything, Anytime, Anywhere
"The deadliest weapon in the world is a Marine and his rifle"
scottsbro23 is offline   Reply With Quote
Old 05-24-2008, 10:20 PM   #3 (permalink)
luvbelly's Avatar
X2. I have read many posts that state for a 4x4 you don't want to go over 2 inches for a leveling kit.
2007 Titan KC SE 4x4 Majestic blue with popular package and utility bed option. Westin grill/brush gaurd, Westin nerf bars, Lund sunvisor II W/light kit, extang toneau cover, KC off road lights, vent visors,bug deflector, remote start, PRG leveling kit, Stillen SS dual rear exit cat back, AR Fuel 8 rims with 285-65-18 BFG AT KO's, K2 LED tail lights. Scottsbro23 custom engine cover
luvbelly is offline   Reply With Quote
Old 05-24-2008, 10:25 PM   #4 (permalink)
Is there anything to be done besides removing the kit or can i use say, limiter straps, or bump stops to keep it from dropping completly.I like the way it sits when it's levelled (should have came this way from the factory).
Old 05-25-2008, 09:45 AM   #5 (permalink)
you could buy new upper arms.
asher is offline   Reply With Quote
Old 05-25-2008, 11:25 AM   #6 (permalink)
06_SMOKE_SE_CC's Avatar
+1, or get a 2" kit instead of the 2.5" one
cst///radflo///sway-a-way///hankook///deaver///pioneer///t-rex///deathreat
...only the best for my truck...
06_SMOKE_SE_CC is offline   Reply With Quote
Old 05-25-2008, 02:00 PM   #7 (permalink)
chieflikalotapus's Avatar
i have a 2.5 kit and im 4x4. i have no problems with the arm hitting. i didnt even have to put new stops. try taking it off and then reinstall ensure that all bolts are tight
MODS: fiji blue pearl paint,33x12.50 toyo mt,20x10 eagle alloys, 2.5 level kit,1" block rear,BullyDog Tuned,k&n air intake,flowmaster exhaust,Detroit trutrac,10k hid kit
chieflikalotapus is online now   Reply With Quote
Old 05-25-2008, 02:15 PM   #8 (permalink)
or cut a lil tab outta the bucket
to go look....
o the drivers side upper control arm.... on the side closest to the driver floor board. look for any rubbing issues where the arm would touch the bucket.
and either cut a lil "v" into the bucket.....or get some bigger bump stops
AZZ Titan is offline   Reply With Quote
Old 05-25-2008, 10:32 PM   #9 (permalink)
Just take a grinder and grind down the lip on the bucket. ten min. fix
Old 05-28-2008, 11:45 PM   #10 (permalink)
Hey thanks guys ,i'll crawl under my truck and take alook....
Old 05-30-2008, 07:46 PM   #11 (permalink)
BECHLYF's Avatar
You won't be able to see the uca and coil bucket from under the truck try sticking you head in the wheel well above the tire if you have room
Old 06-02-2008, 10:01 AM   #12 (permalink)
Titster's Avatar
Ok guys, here it goes!!! I got a leveling kit from top gunz on ebay. Before installing the leveling kit there was no thumping, or any other kind of noise what so ever. After installing the leveling kit, I started noticing a thumping and a noise I thought was the stabilizing bar bushings. I felt I had purchased a bad quality product (the leveling kit), and even considered removing it. I looked on the forums here and I sent a message to someone who had the same problem here and he told me he replaced the struts and that fixed it. So I did, and guess what??? It fixed it. All thumping and screeching went away. If you are thinking of installing a leveling kit, you might as well buy new struts and replace them while your truck is in the shop. I used the Rancho 9000xl 9pos. adjustable and they are great. They come with a lifetime warranty and the people at Rancho's warranty department are the best. I needed mine replaced and they sent me replacements no questions asked and they paid shipping and handling. I hope this helps and if anyone has any questions feel free to ask, I am no expert but I had these problems and this was the solution.
Titster is offline   Reply With Quote
Beating a Dead Horse: Drivetrain Clunk goofytim Titan Engine, Transmission & Drivetrain 12 01-01-2006 09:42 AM
I took a beating HaterHurter War Stories 83 08-26-2005 10:48 PM
Beating a dead horse mkelee Titan General Discussion 3 05-24-2005 09:38 PM
are titan's really 'underbraked' (one last look at a dead horse...hopefully) stick Titan General Discussion 22 01-23-2005 04:07 PM
Beating a dead horse subcpo Titan Wheels, Tires & Brakes 8 11-12-2004 08:50 AM
