i have a 07' titan with a 6'' procomp lift on. i have the saw coilovers also. i want a cpl more inches but after reading i would really like to try and stay away from a body lift. well i read from other post on the back i could buy them leaf springs which raise it 3.5 i think then put blocks under them. not sure about the front though.....i read that they have somthing like a spacer to put on top of my coilover? then i read about the spindle lift............. kinda confused.......
If you purchase a set of PRG Upper Control Arms- CLICK HERE
and when you call, tell Greg you have a ProComp lift, he'll hook you up with the correct size spacer, to allow for the most amount of lift with that setup, about another inch.
You could also purchase a set of SAW (Sway-A-Way) or RadFlo coilover shock assemblies for upfront and adjust the preload to get some additional lift as well (probably another inch, maybe more)
For the back:
Replace the factory leaf springs with this 4" Deaver "Race Pack" and leave the 3" ProComp block installed.
You'll also need to replace the rear shackles with the PRG ones
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government. - Thomas Jefferson
you can do a search and find tons of info on the spindle and it's add-ons but 54 gave you ^^ all the info to just add on to what you already have
------------------------ "Wait a minute. What did you just say? You're predicting $4-a-gallon gas? ... That's interesting. I hadn't heard that." --George W. Bush, Feb. 28, 2008
You should be able to get up to 9" of lift with your 6" procomp and SAW's.
2006 Titan XE 4x4 (PRG 4" Performance package)
2003 Evolution VIII (358awhp/354awtq) that's on 91octane,stock boost, stock turbo.
2007 GSXR1000 (not enough road to touch redline)
"Dream as if you'll live forever, live as if you'll die tommorow" : James Dean.
I don't think that will work well w/o new UCA's, I'm having major UCA contact right now w/ my procomp, saws, and stock UCAs.
