Old 06-27-2008, 01:48 PM   #1 (permalink)
cguerra's Avatar
What do I do rear prg shackle noise?
my new prg lift shackles are really makin noise
just started doin it they have been on about 4 months
any ideas?
Corey
2008 SE,4x4, crew cab, 6" procomp lift with 2.50" sways,rear dvd (for the kids), black KMC 18" monsters
35" toyos, rear 2.25" sways piggyback reservoirs, with a 2.5" leaf pack, defiant light bar w/3 hella 1000's, prg shackles, sirius radio
cguerra is offline   Reply With Quote
Old 06-27-2008, 02:10 PM   #2 (permalink)
Re: What do I do rear prg shackle noise?
welcome to the world of poly bushings!! haha, I think someone makes a poly bushing lube to quiet it down, google it bro!!
fivepointnine is offline   Reply With Quote
Old 06-27-2008, 03:00 PM   #3 (permalink)
Not sure if you can grease it too well w/o removal, but you might try spraying it with Super Lube.
http://www.super-lube.com/what-is-super-lube-ez-158.htm
Old 06-27-2008, 04:34 PM   #4 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Is it squeaking or clunking? If its squeaking, use Valvoline Durablend grease (you can use Superlube but its expensive and hard to get). If its clunking, tighten the bolts a bit more.
Old 06-27-2008, 05:07 PM   #5 (permalink)
DeadRiver's Avatar
Send a message via AIM to DeadRiver
Greg, should I so this prior to installing??
2* | AEM Brute Force | 2" NCD Leveling Kit | PRG Shackles| 20" Konig Coastal Wheels w/ 305/50 R20 Nitto Terra Graplers | Aries Bull bar w/ 2 Hella 500 Driving Lights |Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | BB's Extang Trifecta Lease with option to buy
The Urinator™
DeadRiver is online now   Reply With Quote
Old 06-28-2008, 11:33 AM   #6 (permalink)
cguerra's Avatar
Thanks greg,
I will try that monday in the evening,
It is for sure a squeak right now like the old toyotas do when you put upper arms on them you know what I mean?
I will try it and post on status
thanks guys,
corey
Corey
Old 06-28-2008, 01:54 PM   #7 (permalink)
Just coat the lower mount (inside the bracket)with a bit of grease. Dont worry about the upper, it cant squeak.
Old 07-01-2008, 03:29 PM   #8 (permalink)
cguerra's Avatar
just coated the shackles with grease we'll see how we do got to drive about 100 miles right now.
greg,
one thing I noticed is on the lower mount bracket side closest to the tire there are two little notches on the stock metal that are tearing the s**t out of my new shackle bushings. have you seen this on the 08's or is mine just a lucky one.
thanks for the help
cguerra
Corey
Old 07-01-2008, 03:52 PM   #9 (permalink)
BECHLYF's Avatar
greg,
thanks for the help
cguerra
dude that is because you did not read the post
Prg Heavy Duty Shackle Install W/ Pics
Tools needed:
floor jack
19mm open end wrenches and or socket set
small pry bar big screw driver
grinder or metal file
OK jack up rear of truck by the bumper or frame
Loosen the bolts attaching the shackle
Remove bolt attaching shackle to frame mount,spring will spring towards bed
With pry bar push leaf spring up to remove 2nd bolt above frame
Grind or file tabs on inside of mount on frame
Install shackle on leaf spring with gusset (support with hole) facing the rear
(don't go thinking its a good idea to install that bolt from the outside toward the the frame because you think its easier, the pointy end will hit the frame and you will have to take it off and reinstall them both again )
With pry bar pull leaf spring down and install bolt
Repeat on opposite side lower truck.
Old 07-01-2008, 04:30 PM   #10 (permalink)
HRTKD's Avatar
I didn't get the grinding of the tabs either. I don't remember seeing anything like that on my Titan. I guess I need to take them off and get that done. It would have helped if the shackles had come with instructions.
Jim
Old 07-01-2008, 04:38 PM   #11 (permalink)
BBtruck's Avatar
I pre-lubed the bushings before install, didn't have to grind the tabs. Come to think of it, maybe 'cause I got it on the 1 inch drop setting it wasn't needed. No rubbing, no noise.
L
My modest mods:
Bilsteins HD front and back, PRG adj. shackles, JBA catback, CF dash kit, BullyDog PP.
BBtruck is offline   Reply With Quote
Old 07-01-2008, 06:00 PM   #12 (permalink)
BECHLYF's Avatar
L
which hole in the shackle you put the bolt (stock -1/2" -1") has nothing to do with the tabs in the shackle mount on the frame that you have to grind or file off or your lower bushing is grooved with lube
Old 07-03-2008, 11:57 AM   #13 (permalink)
cguerra's Avatar
bech,
your right man I missed that post,
so I am going to pull the shackles out this weekend to file those crappy tabs cause I really dont want them chewing up my bushing so fast.
By the way the grease worked like a charm, no more squeak,,,,,,, for now.
I wish I would of read that post more carefully in the first place, at least now I can do both shackles in like 20 minutes with all this practice.lol
Corey
Old 07-04-2008, 12:38 AM   #14 (permalink)
BBtruck's Avatar
Bad assumption on my part. I thought since I was using the 1 in. drop hole on the shackle was the reason I didn't have a problem with those tabs located under the bed above the shackle mount. I stand corrected and will file/grind those down. Unless I'm looking at the wrong thing, the tab is about an inch from the upper bushing.
Does a load in the bed make those tabs contact the bushing?
I did lube both upper and lower bushing just to be on the safe side, didn't know the lower bushing lubing was not needed. Your write up was what gave me the confidence and prompt me to buy and install the PRG shackles, thank you. Obviously I need to read more "How things work".
L
My modest mods:
Rear Drop Shackle Issues??? 1BadTitan Titan General Discussion 19 12-10-2007 08:13 PM
broken shackle on rear spring Juday45 Titan Problems & Dealer Service 13 11-04-2007 07:30 AM
Failed rear Shackle = Leaf spring through bed!!! streetstalkerwj Titan Suspension 14 03-08-2007 10:26 AM
Bed/rear shackle contact... Milehi Titan Problems & Dealer Service 6 03-01-2005 05:12 AM
Anyone ever able to find a Rear lowering/leveling shackle markislive78 Titan Suspension 0 01-05-2005 04:00 PM
