Has any one thought or tried to flip the lower ball joint to put on top of lower a arm? To get more lift up front, figuring the thickness of the a arm is what 1.5" to 2" thick.
loufish 6387 posts · Joined 2004 Add to quote Only show this user #2 · Jun 25, 2008 Going to need an aftermarket arm, and if you have the "extended travel" set-up the arm will then hit or run out of uni-ball rotation...
