Old 07-14-2008, 03:51 PM   #1 (permalink)
Question Axel wrap or just suspension travel
i watched this video that "stuntdriver06" posted a link to in a different thread and much of what I see is normal suspension travel...there is some wrap but nothing I see as abnormal. Whats your take on this?
p.s. Thanks stuntdriver06 for posting link in a previous thread.
http://videos.streetfire.net/video/T...rap_153110.htm
Titanomachy is offline   Reply With Quote
Old 07-14-2008, 05:05 PM   #2 (permalink)
DRTYAZN's Avatar
Re: Axel wrap or just suspension travel
well, looks like his driveshaft is doing just fine and functioning the way it's supposed to be... from what I see, looks like the rear is squatting like it should every time the throttle get's mashed...
Radiant Silver '06 Titan SE CC 4X4 w/BT&OR w/ ATS Fender Flares
PC 6" lift w/ PRG A arms & traction bars, SAW's front/rear combo & Deaver pack
35" PC Xtreme Mud Terrains on 17" Helo Maxx 6's
Volant CAI, PowerAid TBS, Flowmaster 50
DECEPTICON center grill, SS Hood Deflector & Chrome Truck Nutz
DRTYAZN is offline   Reply With Quote
Old 07-14-2008, 06:01 PM   #3 (permalink)
MuskyHunter's Avatar
Titan1080 did a nice video showing axle wrap:
2007 Titan King Cab LE 4x4 : Big Tow: Arctic White : Graphite Leather : Painted Armada Air Dam : Truxedo LowPro Tonneau : Utilitrack Bed Divider : Underseat Storage : BFG Long Trail TA Tour Tires: Bilstein 5100 and Icon Shocks
www.secretlake.net
Old 07-14-2008, 06:52 PM   #4 (permalink)
Old 07-14-2008, 07:02 PM   #5 (permalink)
DRTYAZN's Avatar
well, from my own experience of Titan axle wrap, i managed to have 2 torn tranny/transfer mounts in less than 12k each... I started noticing each incident when I got on it from a stop, I could hear gear rginding sounds from underneath and feel lack of traction... when I put the pedal to the floor from 0, there would be a huge metallic slam, like something slid from the front of the bed to the rear... this is just one of the mechanical faults caused by axle wrap... my fix to the problem was a set of PRG traction bars...
axel-wrap-just-suspension-travel-front.jpg  axel-wrap-just-suspension-travel-frnt.zm.jpg  axel-wrap-just-suspension-travel-ft.drvr.jpg  axel-wrap-just-suspension-travel-ft.psgr.jpg
Old 07-14-2008, 07:10 PM   #6 (permalink)
pedalhappy1053's Avatar
Send a message via MSN to pedalhappy1053
Wait a second.......so axle wrap would cause the tranny mounts to fail? and you fix that with the traction bars?
NEXT MOD: UPREV And Trutrac
Performance: K&N FIPK Intake, Throttle Body Spacer, BANKS exhaust
Suspension: 6" Pro Comp Lift, SAW Coilovers with PRG Upper Control Arms
Audio: Alpine CDA-9887 Deck, 2 Pioneer TS-D6902R 6x9 Front Speakers, 2 Kicker 10" L5's, Sundown 1000D Amp, EFX Hyperdrive HD4300 Amp
"Girls love my truck"
Can't wait till I ship out and till I get the Infantry MOS I want.
pedalhappy1053 is offline   Reply With Quote
Old 07-14-2008, 07:18 PM   #7 (permalink)
DRTYAZN's Avatar
YUP! the great engineering that went into the development of our tranny mounts obviously sucked... the mount is basically a rubber circular tube, has a solid core, with raised lips that go wider and upwards... I think it's designed to "cushion" the ride, but does nothing to maintain forward/rear movement, so the outter edges rip and keep tearing until the thin outter edges rip completely from the solid core...
Old 07-14-2008, 07:20 PM   #8 (permalink)
OK thats next on m y list, the traction bars. Ive already went thru 2 tranny mounts and I got one broken right now.
Old 07-14-2008, 07:24 PM   #9 (permalink)
WoW!!! 2 mounts in 12k, not good. I'll have to keep an eye/ear on that. What year is your titan? Have you heard of others going threw mounts?
What does a set of PRG traction bars go for? Do they affect anything in a negative way?
Old 07-14-2008, 07:27 PM   #10 (permalink)
As I see from last post, yea there are others!!! Doesn't say much for reliability. I would have done without a smoother ride for better designed mounts.
Is the wrap also responsible for the shackle failures?
Old 07-14-2008, 07:41 PM   #11 (permalink)
DRTYAZN's Avatar
don't know if it is a factor with shackle failure... IMO, the OEM shackles just aren't made too well, bad welds that allow it to peel open...
axel-wrap-just-suspension-travel-stock-20vs-20pgr-20titan-20shackle.jpg  axel-wrap-just-suspension-travel-titanshackle-20002.jpg
Old 07-15-2008, 06:59 AM   #12 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
The tranny mount issue is really a 4wd problem and only on lifted trucks. But I see it all the time on trucks that tow or guys who like to accelerate hard. As the driveshaft plunges into the transfercase, it trys to push the TC up and forward and puts a lot of load on the mount, eventually this mount fails. Even though there is a slip yoke, there is still alot of "side loading" that puts a tremendous force, for a brief moment, into the tranny mounts. If the DS were at stock angles it would be much less likely to happen. But traction bars keep the axle from rotating and let the tranny mounts live a longer, happier life.
Old 07-15-2008, 07:19 AM   #13 (permalink)
Blackbeauty's Avatar
Not to mention how much better the truck seems to "hook up". Plus.. they look REALLY COOL!!!!!
Old 07-15-2008, 07:29 AM   #14 (permalink)
Its obvious why their failing, the side walls of factory mount don't continue all the way along the side of shackle. Aftermarket ones do. Its no wonder their failing. Are they braking only from overloading or are their other things that cause them to fail? Was that yours that broke and what caused it to?
Old 07-15-2008, 07:31 AM   #15 (permalink)
That does look bad ***... Is that frame mount already there, or do you have to have that welded on?
PRG Deluxe Mid-travel Suspension CL 8 2WD Titan Suspension 164 08-31-2009 10:56 PM
4x4 Long Travel Suspension 06XERed Titan Suspension 1 08-18-2007 04:54 AM
long travel suspension question aaron77388 Titan Suspension 11 09-20-2006 08:55 AM
My New Long-Travel Suspension Set-up PrerunnerGreg Titan Pictures & Media Post 50 09-16-2006 05:52 PM
Front suspension travel Maksmith Titan General Discussion 10 07-06-2005 06:16 AM
