Old 08-15-2008, 07:47 PM   #1 (permalink)
schiccc's Avatar
2" lowering shackles?
i recently purchased a 08 titan se 2wd and would like to lower it alittle.i dont want to slam it and ruin the ride.i was thinking of starting with 2" lowering shackles first. anybody got a pic of a titan with just 2" lowering shackles.
08.5 titan cc se,22",nismo intake,mbrp exhaust, 2/4 drop,bd programmer,system
07 trailblazer ss,tune,cold air kit & exhaust(wifes)
92 mustang notch,bolt ons,wheels,suspension
schiccc is offline   Reply With Quote
Old 08-15-2008, 09:56 PM   #2 (permalink)
krh2's Avatar
Re: 2" lowering shackles?
You need these:
PRG Products
krh2 is offline   Reply With Quote
Old 08-15-2008, 10:13 PM   #3 (permalink)
gabriel c.'s Avatar
it wont lower 2'' more like 1" if you dont tow heavy remove a leaf and it will even out the back with the front. and did i mention its a free mod.
third coast titans
gabriel c. is offline   Reply With Quote
Old 08-15-2008, 10:31 PM   #4 (permalink)
krh2's Avatar
Copy that, but then it just aint a truck....
Old 08-15-2008, 11:38 PM   #5 (permalink)
Timoteo's Avatar
I just installed these PRG shackles. Very subtle, slightly over an inch drop, you really don't directly notice it, it just takes that nose dive look away. However, I'm a 2007 and I hear the 2008's ride a little more level form the factory. You really can't do any more than these shackles do, you are approaching the bottom of the bed with these. Here's a shot with the shackles in the fully lowered position. Easy to install, by the way. Just jack up one side at a time to just where the tire is barely touching the ground, pop off two bolts, slap new shackle in, move to other side, repeat.
2-lowering-shackles-img_0184.jpg  2-lowering-shackles-img_0185.jpg  2-lowering-shackles-img_0186.jpg
__________________________________________
2007 Black KC SE: Nismo Exhaust, Injen Intake,
Bully Dog, Armada Airdam, Truxedo Bedcover,
debadged, rear lowered with PRG shackles,
PML transmission pan.
Timoteo is offline   Reply With Quote
Old 08-16-2008, 12:39 AM   #6 (permalink)
IIRC, PRG called BS on the Ebay 2" drop shackles because you would need to cut a hole in the bed to clear them if the shackles were long enough to provide a full 2" drop. I wouldn't recommend just pulling a leaf as you will probably get axle wrap from hell.
Old 08-16-2008, 08:41 AM   #7 (permalink)
BoneDaddy's Avatar
Here is a picture of mine with PRG shackles set to the lowest setting, a leaf removed, and the Roadmaster Active Suspension installed. The shackles and the leaf brought it down... and the RAS brought it back up about 3/4" AND gave me back some of that capacity lost by removing the leaf. It also acts like both traction and sway bars. Ohhh... and change out those lame rear shocks!!!
I also brought the front down a tad with the adjustable coilovers.
You can do just the shackles, but I don't think they will buy you more than 3/4" - 1" by themselves. Bottom line... there is no "easy button" for this one.
Good luck to you.
BoneDaddy is offline   Reply With Quote
Old 08-16-2008, 05:18 PM   #8 (permalink)
schiccc's Avatar
thanks for the replies,i may just do a full lowering kit instead(front coils and rear leafs).
Old 11-06-2009, 11:57 PM   #9 (permalink)
Go to Canuck Motorsports.com for your 2" drop shackles
gary higgs is offline   Reply With Quote
Old 11-07-2009, 06:34 AM   #10 (permalink)
O-FiveCC's Avatar
Thats the Springtech shackle you are talking about^^^^...I used one and only got about an inch...Of course, the OP has his truck up for sale now
http://videos.streetfire.net/video/0...-It_691843.htm
IRC VK56 Pit Crew Chief
13.842 at 96.98--8.78 at 77.75 1/8th 1.92 60' NA FST (pre-PGM)
2005 XE Crew Cab
Performance: Nismo CAI, Nismo Longtubes/NO Cats, Uprev, JBA cat-back, Tru-track, 07 intake, Hellwig Traction Springs
Interior: Nismo SS gauges, 2 Sundown 9" Monitors
Exterior: painted Armada air-dam, 6 piece Billet grille, chrome handles, SE Mirrors, DDM 8000k HIDS, Bilstein 5100's, Springtech 2" shackles, OEM 20's
NY-Trex wet kit, TransGo shift kit
O-FiveCC is offline   Reply With Quote
Towing with lowering shackles 06titancrewse Titan Towing & Hauling 7 08-21-2009 10:52 PM
F/s Lowering Shackles crazyej Buy/Sell 0 08-03-2007 06:54 PM
WTB: Lowering Shackles 2K6Smoked Buy/Sell 4 08-01-2007 08:57 PM
"stupid" question about lowering shackles...SQUEAKS and OTHER NOISES!! maestro Titan General Discussion 1 03-12-2006 06:39 PM
Lowering Shackles 1BadTitan Titan Suspension 11 02-19-2005 02:26 PM
