Old 08-22-2008, 09:17 AM   #1 (permalink)
Exclamation Install help needed. Bilstein 5100
I got the Bilstein 5100's & the shop says they won't fit: can't compress the spring far enough & there are no bushing plates for top bracket & need more bushings/bump stops. What's goin' on?
coolest dad is offline   Reply With Quote
Old 08-22-2008, 09:24 AM   #2 (permalink)
Blackbeauty's Avatar
Re: Install help needed. Bilstein 5100
Firstly, where you buy them makes a difference.. Secondly, you should use the washer from your stock shocks as well as the supplied washer from the 5100's or it may pop through the mount. Can't compress the spring enough? Find a different shop......
Old 08-22-2008, 09:25 AM   #3 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Try a different shop. I can do a set of these in a about 15 minutes. You do need a good spring compressor though.
The Following User Says Thank You to PrerunnerGreg For This Useful Post:
coolest dad (09-03-2008)
Old 08-22-2008, 09:26 AM   #4 (permalink)
Will the increased spring compression stiffen the ride or will these shocks account for that in the damping? I got them from a shop in Detroit online.
Old 08-22-2008, 10:24 AM   #5 (permalink)
Send a message via Yahoo to sportbiker929
you will love'em
sportbiker929 is offline   Reply With Quote
Old 08-23-2008, 04:13 PM   #6 (permalink)
+1 Find a shop that has the capability to do it. I watched my guy do the install and it kicked his *** but he got it done. But I am loving the stability and ride of my Bilsteins!
Blizzard KC 4x4 SWB
RF, Tow pkg, High Utility bed, Step assist
Added: Fog lamps, Stillen CAI, 22" Magnaflow, Bilstein 5100's (front's at 1"), 20x8 ATX VICE, 305/55/20 Nitto Terra Grapplers, Bully Dog tuned.
Future: True-trac.
"Anyone can kick in a door; but only a select few can tell us which door to kick, at the right time, when the right target is there."
cwbrow2 is offline   Reply With Quote
Old 08-25-2008, 07:09 PM   #7 (permalink)
07cajuntitan's Avatar
I just installed mine over the weekend. The shocks went on without a hitch - the spacers were another story for another thread.
The 5100's come with 1 washer - don't even take it off of the shock - leave it there, because that's where it goes. When you take off the factory shock, the factory boot has a washer built into the top of it. The washer that comes with the Bilstein takes the place of it - just above the shock & under the rubber gasket. The washer that was on the top goes back into place.
I brought the coilovers to a Firestone shop to compress the spring & put the new shock inside of the coil. Had I NOT stood outside of the roll-up bay door they WOULD HAVE done it completely wrong. I had to break their "employees only" policy and go show them the correct configuration even though I handed them Bilstein's instructions with the shocks. Even after they installed the shocks I had to make then compress the springs again to properly allign the bolts so I could get them back on the truck.
It's amazing how much people don't give a crap about their jobs. These guys are supposed to be the experts.
2007 Titan SE KC 4x4 Granite --- Geaux Tigers!!!
07cajuntitan is offline   Reply With Quote
Old 09-03-2008, 10:33 PM   #8 (permalink)
Finally just did 'em myself... took off the Rancho's & went to a body shop. They switched the springs in 25 minutes, took 'em back home, popped right on. I went with the top setting and lowered my headlights 2 turns. Rides great. The Rancho's could be pressed all the way down with only leaning on them! (Shot!!). The 5100's seem to take weight in the bed better also. So far, so good. Thanks to all who helped out!
Bilstein 5100 vs. Bilstein HD PRJ Titan Suspension 20 12-06-2008 01:22 AM
bilstein 5100 shocks question wl07 Titan Suspension 13 10-13-2008 08:38 PM
Bilstein 5100 review username Titan Suspension 23 08-30-2008 07:12 PM
Bilstein 5100 install question dank78 Titan Suspension 10 04-22-2007 10:14 PM
Bilstein 5100 installation question... dank78 Titan Suspension 11 12-28-2006 09:40 AM
