Old 11-24-2008, 03:34 PM   #1 (permalink)
chargedTitan's Avatar
why different pre-load to level front?
I had my extended length SAW's and PRG upper control arms installed last week. They were set at 2'' of pre-load, but the ride was too stiff, so I dropped them both to 1 +3/4". I forgot to measure before hand, but afterward the drivers side was sitting 3/4" higher. I don't expect it to be exact from side to side, but closer than that. So I re-adjusted, the drivers side now is set at 1+7/8", and the passenger side is at 1+5/8". The passenger side though is still 1/4" higher, even though there is 1/4" less pre-load on that side. My concern with this is it seemed like going from 2" to 1+3/4" made a huge difference in how the truck handled, not nearly as stiff. I would like nearly the same pre-load on each shock so that they are both functioning the same. You guys got any ideas? Is there anything else that could effect ride height?(tire pressure is identical)
06 CC LE -offroad, tow, nav, dvd, sunroof, srs
K + N 77/Stillen hybrid CAI
Borla dual cat back
295 70r17 toyo mud terrains
Sway A Way Coilovers/Radflo rears
Stillen grounding kit
Stillen sway bar-removed(bent)
Stillen headers-removed(leaky)
Stillen superchargers(5 blowers, 5 different intercoolers, removed for the 10th and final time)
chargedTitan is offline   Reply With Quote
Old 11-24-2008, 03:49 PM   #2 (permalink)
Derwud's Avatar
Re: why different pre-load to level front?
Put a thousand miles or so on it and recheck.. You will also want the drivers side a little higher for fuel load and your weight in the truck..
'05 4x4 SE, O/R, Big Tow, Rear Video (Kids favorite option). AMP Powersteps, SAW's all around, TC UGA's and Rear Shackles, Modified Deaver Mini Pack, Air Bags, Moto Metal 951's 18x9, BFG A/T 285/65-18's, Banks Ram Air, Banks Monster Exhaust, Bully Dog Power Pup, PML Rear Diff Cover and Trans Pan. Towing WW FS2300 Toyhauler and all the toys.
The Rhino, The Titan, Truck and Trailer
I HIGHLY recommend PRG Products, SDR Motorsports, Live Wire Whips, and Banks Power
Old 11-26-2008, 05:28 PM   #3 (permalink)
HRTKD's Avatar
It's a progressive load. Moving the ring up 1" may only give you 1/2" of lift but going from 1" to 2" may give you a total of 1.5" of lift. I'm sure there is a math formula that could explain this better (or worse if you don't like math).
Jim
Front and Read Diff Level ? Justintoxicated Titan Engine, Transmission & Drivetrain 3 04-21-2008 05:50 AM
Front level kit patrickhb Titan Performance Modifications 13 02-11-2007 03:49 PM
Front Level Kit midnightmadman Titan Parts & Accessories 15 12-20-2006 01:56 PM
315s or 305s with front level. UT SEABEE Titan Wheels, Tires & Brakes 8 10-26-2006 10:29 PM
level the front or back? gabriel c. Titan Suspension 3 10-17-2006 05:32 PM
