Old 10-11-2009, 06:45 AM   #91 (permalink)
Re: Just installed 3" Rough Country Lift
looks like there is issues using the bilstein 5100 with the rc 3'' kit i am in the middle of the install and have a problem with severe contact between the arm and the coil bucket, not on the lip but where the tube of the arm hits the front upper bracket and the tube hitting the coil bucket. I suspect that the bilsteins not only preload the spring the front springs for less sag but they also are a longer overall assembly from mounting point to mounting point
kyle797 is offline   Reply With Quote
Old 10-11-2009, 11:57 AM   #92 (permalink)
yamatitan's Avatar
Is that with the truck off the ground or on the weight of the truck? If its off the ground put it on the ground and see how much room you have. Mine looked like that with my stock arms off the ground but it never hit when I drove even offroading.
Procomp 6" ($1300.00),SAW coilovers ($1000.00),Rear Sway-away piggybacks ($399.00),PRG Offroad Traction Bars ($489.00), C-30 Deaver pack ($140.00), PRG Shackles ($139.00), PRG UCA ($599.00), NCD 2" SPACER ($89).
37x13.5x18 Toyo MT's ($1900.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
Color Matched Bushwacker Pocket style flares ($600.00)
Stillen Big Brake Kit ($905.00)
Doug Thorley Longtubes ($675.00)
Money wasted so far=$12,420.00
Rough Country 3" lift clavin48 Titan Parts & Accessories 18 12-30-2008 08:40 AM
Rough Country 3" Lift? anmut Titan Parts & Accessories 2 04-04-2008 12:57 PM
Rough Country 2" lift Titanguy86 Titan Parts & Accessories 15 03-24-2005 11:33 AM
Rough Country 2" lift Sammy Sandbag Titan Suspension 19 06-18-2004 06:52 PM
