Re: Lowering Titan
I cut the coils up front and removed a leaf in the rear along with adding some drop shackles from belltech that I think are for a Chevy, but I made them fit. I made some drop shock brackets for the rear shocks out of some brackets for a Tahoe. It took some cutting and welding but work great. I think Dodge brackets will work easier. I havn't figured out the front yet, but I am also bottoming out the front strut. I found some lift/lowering struts by Belltech on the Jegs website that I figured I could set the strut in the lifted position and use my chopped coil so it wouldn't bottom out. I ordered the struts and they should be here the 6th of March. I'll try and get some pics posted tonight, I'm sitting at a 2 1/2" front and 4 1/2" drop so far.
